Efficiency at low power consumption
Well there are 3,84TB PM863 drives available, but TB/USD isnt that good anymore (52 USD/TB). Ebay link here 199 USD per unit.
I would however raise the following points for consideration:
  • sata ssd have relatively low power consumption both when idle and under load
  • you are probably going to use zfs or similar filesystem, i.e software defined volumes with redundancy
  • using large number of drives is therefore not an significant issue, only powering them
  • daisy chaining power for sata ssds is safer and easier than hdds
  • hdplex PSUs can be also daisy chained
  • ALTERNATIVE: separate disk shelf unit with its own psu, then connect it to head unit via SAS externally?
There is one review of PM863 960GB variant drive with deitailed power readings here, should be valid with small upward margin of error to max capacity drive as well.
IDLE: 1,3W
MAX LOAD 4,5-5W
I would consider disk shelf to be outlier option. While it would solve the power supply and expand-ability issue, they are not exactly power efficient as you would consider it.
Plus they are enteprise use only gear, ie. expensive. Then you have to source AIC sas controller for the head unit, and used older ones consume around 10W alone.
Yeah, for that price I might aswell get new 870 Evos.
Yes. Though I checked reviews for a 160W pico PSU and someone was saying that a ZFS scrub with 4 HHDs on it wasn’t working due to low power through the SATA/molex connector. So I imagine that 6 SSDs will meet the same faith.
Unfortunately not an option, I don’t have the space for it. Maybe it can be in the future and if the need for space exceeds the case capacity.
Tom’s Hardware measured THIS PSU at 74.5% efficiency at 20W. I can get it new for 100$ and I’m very tempted to because there’s no efficiency curve or indipendent review about the HDPlex 250W.
I think you underestimate power draw difference between SATA SSD and HDDs, they can be massive, hence my remark. Assuming 2,5 sata ssd vs 3,5’ 7200 HDD its 5W vs 20-25W peak power use remember? And those sata ssd will not reach peak use very often even due to relative performance difference.
You can power a lot of sata ssd from 5V power rail even on anemic power supplies. I would caution against picoPSU when hdplex GAN is availble though.
With picopsu being DC to DC PSU only, you now have to source AC to DC power adaptor with uknown or very hard to quantify efficiency. Easily available ones are not great, and will tank your overall efficiency.
No such compications with HDPLEX GAN, since it has AC to DC stage integrated.
They are servicable though, I ran HP N54L microserver with 4x3TB 3,5’ WD REDs on 120W picopsu from minibox.com (no longer exists I am afraid) for years and had no issues. It was a close shave power wise, but it worked. Those drives were not however 7200rpm, but weird 5000-5200 varidrive whatever WD sold then.
I think I reached 15-25W idle state with that box, but don’t have the machine or measurement notes any longer.
Otherwise any gold or platinum certified ATX PSU is good candidate.
Exactly. In fact more than 3 HDDs is out of the question. But I know that SSDs won’t ever be saturated and don’t go 100%, so never reach peak power consumption. But I don’t like to gamble.
I’m also wary of them when the HDPlex GaN is available. I’m seriously considering, but still no efficiency chart so.
I found the minibox TX160 and that had the negative review about the ZFS scrub. I’d buy that with the 192W AC/DC and I hope that’s efficient enough, over 75%. But that’s daydreaming really, I don’t think there are many, if any, PSUs that’s even better than that.
Yeah, that’s why I was thinking about that EVGA PSU I linked before.
Thanks for all the help!
here is good thread about 12V power supplies: Power Supply - A Guide to 12V PSU | SFF.Network
(but there are focusing on small-sized units)
