Lower clocks doesn’t necessarily mean better stability / compatibility.
If you are looking for the least amount of trouble, get B-die.
The higher the tflops the better
Doesn’t matter if it’s amd or Nvidia really on pc.
There is a requirement spec if you Google it.
Minimum System Requirements Cinema 4D and BodyPaint 3D. The GPU renderer requires an NVIDIA or AMD graphics card on Windows or AMD on MacOS that supports OpenCL 1.2 or newer. Metal support requires MacOS 10.13.2 or newer. We recommend at least 4 GB VRAM for GPU rendering.
