ECC detection in KVM guest
Hello y’all,
This is my first post on this board, but I’m amped to join the community!
Here is my question:
If KVM were running on a ECC host system, would the KVM guests be able to detect (and utilize) any ECC features that visible to the KVM host?
At a minimum, I’d like to know if the guest VM would indicate so with the following command:
dmidecode --type memory
Any additional mechanisms of verification would be great.
The reason why this is interesting to me is because I have been itching to condense several of my various physical machines into a single rig. The ideal situation is where I could have my NAS, dev VMs, and gaming platform all running on the same box. The important piece is that I need to know that ZFS won’t be compromised while running on a FreeNAS guest. (HBA PCIe passthrough is assumed). I guess that if this isn’t possible, then the only fallback situation is to run Proxmox or Unraid as the host OS, because FreeNAS cannot do GPU passthrough (yet).
Until Threadripper, this would have been very cost or performance prohibitive, but now it seems like the pieces might be there.
thanks in advance!
In theory your VM’s will utilize ECC, as ECC operates at the hardware level and your guests will benefit even if the hypervisor is abstracting the hardware away from them.
What can sometimes be tricky is verifying that ECC is correctly enabled - you would need to do this at the host OS/hypervisor level. If you can detect it there you know the guests will also benefit.
In my experience I usually just check the BIOS settings to see its enabled and leave it at that, but I’m aware that with some motherboards and ram combos things are not always what they seem - hence the need to verify in the host OS.
That turns out to be a surprisingly interesting question.
There’s not a whole lot that neither a guest nor a host can do with the ECC information - correctable errors get corrected at the hardware layer, in-correctable errors are presumably signalled by the hypervisor in some way.
Different hypervisors deal with ECC in different ways - VirtualBox doesn’t make anything visible via dmi whereas ESXi does provide the ECC memory error counters via an emulated interface. No idea about KVM (I don’t have anything convenient running under KVM).
I wouldn’t worry about running ZFS in a vm; the host takes care of ECC. ZFS doesn’t really need ECC any more than any other filesystem (there’s a reason why no proper server lacks ECC).
Thanks for the feedback BGL & VeryZ.
As you can see from my specs (below), I am also running ESXi with hardware that supports ECC operation. Early on, I configured the BIOS/UEFI to support ECC operation and verified that it was being reported as such via a Debian Live boot CD. After verifying that the ECC was working, I jumped to an ESXi installation which has since been upgraded a number of times, but never looked farther into it.
While correct that ZFS does not require ECC, and that all proper servers should have ECC, I’ve read numerous articles that suggest that without ECC, the resilvering process that ZFS systems run to correct bit-rot may instead induce wide-scale data corruption if there are undetected memory errors.
Anyway, because this is an interesting topic, and I am about to go from ESXi to Debian+KVM, I figured that I would rerun the ECC checks and post the results on this thread in case anybody else is interested in this topic.
Thanks!
ESXi 6.5.0 (Build 4887370)
Intel Xeon E3-1245 v2
ASUS P8C WS
4x 8GB Kingston DDR3 1600 ECC Unbuffered Memory
IBM M1015 HBA (flashed to LSI2008 IT mode)
ESXi 6.5 (free) findings:
On my ESXi host, it appears that ESXi does not detect any ECC (reliable) memory. Perhaps this is because I need to change a default configuration setting somewhere?
[[email protected]:~] esxcli hardware memory get
   Physical Memory: 34031271936 Bytes
   Reliable Memory: 0 Bytes
   NUMA Node Count: 1
Update:
It seems that “reliable memory” is not the same thing as standard ECC, so this result is really meaningless.
So if knowledge of ECC could be passed to the ESXi guests, then I would have expected it to see it in the following tests. Since the host doesn’t even report “reliable” ECC memory, any hope of a guest also reporting it is dashed…
FreeNAS-9.10.2-U1 (86c7ef5) guest in ESXi host:
[email protected]:~$ dmidecode --type memory
# dmidecode 3.0
Scanning /dev/mem for entry point.
SMBIOS 2.7 present.
Handle 0x0006, DMI type 5, 46 bytes
Memory Controller Information
	Error Detecting Method: None
	Error Correcting Capabilities:
		None
	Supported Interleave: One-way Interleave
	Current Interleave: One-way Interleave
	Maximum Memory Module Size: 32768 MB
	Maximum Total Memory Size: 491520 MB
	Supported Speeds:
		70 ns
		60 ns
	Supported Memory Types:
		FPM
		EDO
		DIMM
		SDRAM
	Memory Module Voltage: 3.3 V
	Associated Memory Slots: 15
		0x0006
		0x0007
		0x0008
		0x0009
		0x000A
		0x000B
		0x000C
		0x000D
		0x000E
		0x000F
		0x0010
		0x0011
		0x0012
		0x0013
		0x0014
	Enabled Error Correcting Capabilities:
		None
Handle 0x0007, DMI type 6, 12 bytes
Memory Module Information
	Socket Designation: RAM socket #0
	Bank Connections: None
	Current Speed: Unknown
	Type: EDO DIMM
	Installed Size: 8192 MB (Single-bank Connection)
	Enabled Size: 8192 MB (Single-bank Connection)
	Error Status: OK
Handle 0x0008, DMI type 6, 12 bytes
	Socket Designation: RAM socket #1
	Type: DIMM
	Installed Size: Not Installed
	Enabled Size: Not Installed
	Error Status: OK
Handle 0x0009, DMI type 6, 12 bytes
	Socket Designation: RAM socket #2
	Type: DIMM
	Error Status: OK
Handle 0x000A, DMI type 6, 12 bytes
	Socket Designation: RAM socket #3
	Type: DIMM
	Error Status: OK
Handle 0x000B, DMI type 6, 12 bytes
	Socket Designation: RAM socket #4
	Type: DIMM
	Error Status: OK
Handle 0x000C, DMI type 6, 12 bytes
	Socket Designation: RAM socket #5
	Type: DIMM
	Error Status: OK
Handle 0x000D, DMI type 6, 12 bytes
	Socket Designation: RAM socket #6
	Type: DIMM
	Error Status: OK
Handle 0x000E, DMI type 6, 12 bytes
	Socket Designation: RAM socket #7
	Type: DIMM
	Error Status: OK
Handle 0x000F, DMI type 6, 12 bytes
	Socket Designation: RAM socket #8
	Type: DIMM
	Error Status: OK
Handle 0x0010, DMI type 6, 12 bytes
	Socket Designation: RAM socket #9
	Type: DIMM
	Error Status: OK
Handle 0x0011, DMI type 6, 12 bytes
	Socket Designation: RAM socket #10
	Type: DIMM
	Error Status: OK
Handle 0x0012, DMI type 6, 12 bytes
	Socket Designation: RAM socket #11
	Type: DIMM
	Error Status: OK
Handle 0x0013, DMI type 6, 12 bytes
	Socket Designation: RAM socket #12
	Type: DIMM
	Error Status: OK
Handle 0x0014, DMI type 6, 12 bytes
	Socket Designation: RAM socket #13
	Type: DIMM
	Error Status: OK
Handle 0x0015, DMI type 6, 12 bytes
	Socket Designation: RAM socket #14
	Type: DIMM
	Error Status: OK
Handle 0x0028, DMI type 16, 23 bytes
Physical Memory Array
	Use: System Memory
	Error Correction Type: None
	Maximum Capacity: 9 GB
	Error Information Handle: Not Provided
	Number Of Devices: 64
Handle 0x0029, DMI type 17, 34 bytes
Memory Device
	Array Handle: 0x0025
	Error Information Handle: No Error
	Total Width: 32 bits
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #0
	Bank Locator: RAM slot #0
	Type: DRAM
	Type Detail: EDO
	Speed: Unknown
	Manufacturer: Not Specified
	Serial Number: Not Specified
	Asset Tag: Not Specified
	Part Number: Not Specified
	Rank: Unknown
	Configured Clock Speed: Unknown
Handle 0x002A, DMI type 17, 34 bytes
Memory Device
	Total Width: Unknown
	Data Width: Unknown
	Size: No Module Installed
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #1
	Bank Locator: RAM slot #1
	Type: DRAM
	Type Detail: Unknown
	Speed: Unknown
	Rank: Unknown
Handle 0x002B, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #2
	Bank Locator: RAM slot #2
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x002C, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #3
	Bank Locator: RAM slot #3
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x002D, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #4
	Bank Locator: RAM slot #4
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x002E, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #5
	Bank Locator: RAM slot #5
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x002F, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #6
	Bank Locator: RAM slot #6
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0030, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #7
	Bank Locator: RAM slot #7
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0031, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #8
	Bank Locator: RAM slot #8
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0032, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #9
	Bank Locator: RAM slot #9
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0033, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #10
	Bank Locator: RAM slot #10
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0034, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #11
	Bank Locator: RAM slot #11
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0035, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #12
	Bank Locator: RAM slot #12
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0036, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #13
	Bank Locator: RAM slot #13
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0037, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #14
	Bank Locator: RAM slot #14
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0038, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #15
	Bank Locator: RAM slot #15
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0039, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #16
	Bank Locator: RAM slot #16
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x003A, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #17
	Bank Locator: RAM slot #17
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x003B, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #18
	Bank Locator: RAM slot #18
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x003C, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #19
	Bank Locator: RAM slot #19
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x003D, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #20
	Bank Locator: RAM slot #20
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x003E, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #21
	Bank Locator: RAM slot #21
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x003F, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #22
	Bank Locator: RAM slot #22
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0040, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #23
	Bank Locator: RAM slot #23
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0041, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #24
	Bank Locator: RAM slot #24
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0042, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #25
	Bank Locator: RAM slot #25
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0043, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #26
	Bank Locator: RAM slot #26
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0044, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #27
	Bank Locator: RAM slot #27
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0045, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #28
	Bank Locator: RAM slot #28
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0046, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #29
	Bank Locator: RAM slot #29
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0047, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #30
	Bank Locator: RAM slot #30
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0048, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #31
	Bank Locator: RAM slot #31
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0049, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #32
	Bank Locator: RAM slot #32
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x004A, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #33
	Bank Locator: RAM slot #33
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x004B, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #34
	Bank Locator: RAM slot #34
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x004C, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #35
	Bank Locator: RAM slot #35
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x004D, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #36
	Bank Locator: RAM slot #36
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x004E, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #37
	Bank Locator: RAM slot #37
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x004F, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #38
	Bank Locator: RAM slot #38
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0050, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #39
	Bank Locator: RAM slot #39
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0051, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #40
	Bank Locator: RAM slot #40
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0052, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #41
	Bank Locator: RAM slot #41
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0053, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #42
	Bank Locator: RAM slot #42
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0054, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #43
	Bank Locator: RAM slot #43
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0055, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #44
	Bank Locator: RAM slot #44
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0056, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #45
	Bank Locator: RAM slot #45
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0057, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #46
	Bank Locator: RAM slot #46
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0058, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #47
	Bank Locator: RAM slot #47
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0059, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #48
	Bank Locator: RAM slot #48
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x005A, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #49
	Bank Locator: RAM slot #49
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x005B, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #50
	Bank Locator: RAM slot #50
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x005C, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #51
	Bank Locator: RAM slot #51
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x005D, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #52
	Bank Locator: RAM slot #52
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x005E, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #53
	Bank Locator: RAM slot #53
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x005F, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #54
	Bank Locator: RAM slot #54
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0060, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #55
	Bank Locator: RAM slot #55
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0061, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #56
	Bank Locator: RAM slot #56
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0062, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #57
	Bank Locator: RAM slot #57
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0063, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #58
	Bank Locator: RAM slot #58
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0064, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #59
	Bank Locator: RAM slot #59
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0065, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #60
	Bank Locator: RAM slot #60
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0066, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #61
	Bank Locator: RAM slot #61
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0067, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #62
	Bank Locator: RAM slot #62
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0068, DMI type 17, 34 bytes
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Locator: RAM slot #63
	Bank Locator: RAM slot #63
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Handle 0x0069, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #0
	Bank Locator: NVD #0
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x006A, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #1
	Bank Locator: NVD #1
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x006B, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #2
	Bank Locator: NVD #2
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x006C, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #3
	Bank Locator: NVD #3
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x006D, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #4
	Bank Locator: NVD #4
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x006E, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #5
	Bank Locator: NVD #5
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x006F, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #6
	Bank Locator: NVD #6
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0070, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #7
	Bank Locator: NVD #7
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0071, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #8
	Bank Locator: NVD #8
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0072, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #9
	Bank Locator: NVD #9
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0073, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #10
	Bank Locator: NVD #10
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0074, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #11
	Bank Locator: NVD #11
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0075, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #12
	Bank Locator: NVD #12
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0076, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #13
	Bank Locator: NVD #13
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0077, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #14
	Bank Locator: NVD #14
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0078, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #15
	Bank Locator: NVD #15
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0079, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #16
	Bank Locator: NVD #16
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x007A, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #17
	Bank Locator: NVD #17
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x007B, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #18
	Bank Locator: NVD #18
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x007C, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #19
	Bank Locator: NVD #19
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x007D, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #20
	Bank Locator: NVD #20
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x007E, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #21
	Bank Locator: NVD #21
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x007F, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #22
	Bank Locator: NVD #22
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0080, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #23
	Bank Locator: NVD #23
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0081, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #24
	Bank Locator: NVD #24
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0082, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #25
	Bank Locator: NVD #25
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0083, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #26
	Bank Locator: NVD #26
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0084, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #27
	Bank Locator: NVD #27
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0085, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #28
	Bank Locator: NVD #28
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0086, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #29
	Bank Locator: NVD #29
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0087, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #30
	Bank Locator: NVD #30
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0088, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #31
	Bank Locator: NVD #31
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0089, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #32
	Bank Locator: NVD #32
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x008A, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #33
	Bank Locator: NVD #33
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x008B, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #34
	Bank Locator: NVD #34
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x008C, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #35
	Bank Locator: NVD #35
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x008D, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #36
	Bank Locator: NVD #36
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x008E, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #37
	Bank Locator: NVD #37
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x008F, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #38
	Bank Locator: NVD #38
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0090, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #39
	Bank Locator: NVD #39
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0091, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #40
	Bank Locator: NVD #40
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0092, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #41
	Bank Locator: NVD #41
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0093, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #42
	Bank Locator: NVD #42
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0094, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #43
	Bank Locator: NVD #43
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0095, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #44
	Bank Locator: NVD #44
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0096, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #45
	Bank Locator: NVD #45
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0097, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #46
	Bank Locator: NVD #46
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0098, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #47
	Bank Locator: NVD #47
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x0099, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #48
	Bank Locator: NVD #48
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x009A, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #49
	Bank Locator: NVD #49
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x009B, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #50
	Bank Locator: NVD #50
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x009C, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #51
	Bank Locator: NVD #51
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x009D, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #52
	Bank Locator: NVD #52
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x009E, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #53
	Bank Locator: NVD #53
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x009F, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #54
	Bank Locator: NVD #54
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00A0, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #55
	Bank Locator: NVD #55
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00A1, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #56
	Bank Locator: NVD #56
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00A2, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #57
	Bank Locator: NVD #57
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00A3, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #58
	Bank Locator: NVD #58
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00A4, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #59
	Bank Locator: NVD #59
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00A5, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #60
	Bank Locator: NVD #60
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00A6, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #61
	Bank Locator: NVD #61
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00A7, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #62
	Bank Locator: NVD #62
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00A8, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #63
	Bank Locator: NVD #63
	Type: Other
	Speed: Unknown
	Rank: Unknown
Debian GNU/Linux 8 (jessie) guest in ESXi host:
# dmidecode 2.12
SMBIOS 2.7 present.
Handle 0x0008, DMI type 5, 46 bytes
		None
	Supported Speeds:
		70 ns
		60 ns
		FPM
		EDO
		DIMM
		SDRAM
		0x0006
		0x0007
		0x0008
		0x0009
		0x000A
		0x000B
		0x000C
		0x000D
		0x000E
		0x000F
		0x0010
		0x0011
		0x0012
		0x0013
		0x0014
		None
	Type: EDO DIMM
	Installed Size: 16384 MB (Single-bank Connection)
	Enabled Size: 16384 MB (Single-bank Connection)
	Error Status: OK
	Type: DIMM
	Error Status: OK
	Type: DIMM
	Error Status: OK
	Type: DIMM
	Error Status: OK
	Type: DIMM
	Error Status: OK
	Type: DIMM
	Error Status: OK
	Type: DIMM
	Error Status: OK
	Type: DIMM
	Error Status: OK
	Type: DIMM
	Error Status: OK
	Type: DIMM
	Error Status: OK
	Type: DIMM
	Error Status: OK
	Type: DIMM
	Error Status: OK
	Type: DIMM
	Error Status: OK
Handle 0x0016, DMI type 6, 12 bytes
	Type: DIMM
	Error Status: OK
Handle 0x0017, DMI type 6, 12 bytes
	Type: DIMM
	Error Status: OK
Handle 0x002E, DMI type 16, 23 bytes
	Use: System Memory
	Maximum Capacity: 17 GB
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Type Detail: EDO
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: Unknown
	Form Factor: DIMM
	Set: None
	Type: DRAM
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #0
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #1
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #2
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #3
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #4
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #5
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #6
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #7
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #8
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #9
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #10
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #11
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #12
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #13
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #14
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #15
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #16
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #17
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #18
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #19
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #20
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #21
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #22
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #23
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #24
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #25
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #26
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #27
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #28
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #29
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #30
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #31
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #32
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #33
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #34
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #35
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #36
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #37
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #38
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #39
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #40
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #41
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #42
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #43
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #44
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #45
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #46
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #47
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #48
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #49
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #50
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #51
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #52
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #53
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #54
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #55
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #56
	Type: Other
	Speed: Unknown
	Rank: Unknown
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #57
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00A9, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #58
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00AA, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #59
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00AB, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #60
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00AC, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #61
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00AD, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #62
	Type: Other
	Speed: Unknown
	Rank: Unknown
Handle 0x00AE, DMI type 17, 34 bytes
Memory Device
	Data Width: 32 bits
	Form Factor: DIMM
	Set: None
	Locator: NVD #63
	Type: Other
	Speed: Unknown
	Rank: Unknown
ECC is reported in Debian 9.5 running on bare-metal:
# dmidecode 3.0
Getting SMBIOS data from sysfs.
SMBIOS 2.7 present.
Memory Device
	Array Handle: 0x0060
	Error Information Handle: 0x0064
	Total Width: 128 bits
	Data Width: 64 bits
	Form Factor: DIMM
	Set: None
	Locator: ChannelA-DIMM0
	Bank Locator: BANK 0
	Type: DDR3
	Type Detail: Synchronous
	Speed: 1600 MHz
	Manufacturer: Kingston
	Rank: 2
	Configured Clock Speed: 1600 MHz
Handle 0x0060, DMI type 16, 23 bytes
	Use: System Memory
	Error Correction Type: Single-bit ECC
	Maximum Capacity: 32 GB
	Error Information Handle: 0x0061
	Number Of Devices: 4
Memory Device
	Data Width: 64 bits
	Form Factor: DIMM
	Set: None
	Locator: ChannelA-DIMM1
	Bank Locator: BANK 1
	Type: DDR3
	Speed: 1600 MHz
	Rank: 2
Memory Device
	Error Information Handle: 0x0067
	Data Width: 64 bits
	Form Factor: DIMM
	Set: None
	Locator: ChannelB-DIMM0
	Bank Locator: BANK 2
	Type: DDR3
	Speed: 1600 MHz
	Rank: 2
Memory Device
	Data Width: 64 bits
	Form Factor: DIMM
	Set: None
	Locator: ChannelB-DIMM1
	Bank Locator: BANK 3
	Type: DDR3
	Speed: 1600 MHz
	Rank: 2
The next step is to install KVM + QEMU and run the same test within the KVM guest…
short answer “maybe”.
long answer.
The vm would operate through a hypervisor which essentially just reserves a block of memory for the VM, dunno if the host OS/hardware can detect errors in what is essentially a 4gb file just on a ram stick.
And pretty much the same thing happens with anything else (software RAID, filesystems, applications, etc.). ZFS may be marginally more vulnerable than anything else (if you run the scrub process). Or perhaps not.
I’m not familiar enough with ESXi to be sure, but a quick session with the Duck indicates that “reliable memory” isn’t ECC memory but something else (RAID for memory was mentioned). And yes sometimes people are that paranoid.
@VeryZ, you were right that “reliable memory” is not ECC. More like a step beyond that…
I guess then that I don’t have any mechanism to detect ECC in ESXi.
If you are planning on running Debian as the KVM host, then it’s kernel would deal with any ECC events. I don’t see why it would make any sense to pass them on to the guests, Debian is a full operating system and has mechanisms to deal with ECC, unlike ESXI which may be doing some kind of pass thru just because it doesn’t have a mechanism to handle the events. KVM is providing a virtual memory space, why bother to make it breakable?
IIRC what happens in Linux is that single bit errors are corrected and logged, and double bit uncorrectable is potentially more interesting depending on the use case of the page, but I don’t recall seeing any double bit errors, maybe they cause a panic if in kernel space. I have occasionally seen single bit errors corrected and flagged on my E3-1231 under Ubuntu, so I expect that you would see something similar under Debian.
I remember reading a paper many many years ago suggesting that when memory got to 512MB sides then single bit errors should happen occasionally because of alpha particle emission from RAM components. We are long past the time when 512MB of RAM was a huge and unusual amount of memory, and while RAM manufacture may be using better raw materials, certain atoms still statistically experience alpha decay. IIRC cosmic rays were also potentially to blame.
You might like to look at https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/tree/Documentation/admin-guide/ras.rst where it shows how EDAC parameters can be tweaked to get the response you want. There are also some EDAC utilities IIRC, but I haven’t used them.
