What parts and acessories do I need for dual monitors? Cables, mounts, etc... Thanks!
- graphics card that support multi monitors
- all the necessary cables whether DVI HDMI or DisplayPort and adapter if your graphics card and monitors do not coincide
- a monitor mount if you want it. there's nothing wrong with having two on your desk
Plug it in. Done. You don't NEED anything special for dual monitors.
Just plug them in. The only thing you can't do is put one monitor on your graphics card and the other into the motherboard's integrated graphics.
Some motherboards also support multi-monitor if you don't have a graphics card, but chances are they would both take different outputs
awesome thanks!
Yes you need all of this:
http://youtu.be/bHLR3faI7lU?t=7s
