If you have two monitors, one 1440 and one 1080, but you only game on one, does your gpu performance suffer from the second monitor? I will use the second monitor for working situations (spread sheets and such) but I would only use one for gaming.
Slightly. Perhaps 3-5FPS as your GPU has to show both monitors no matter what you are doing on them. But it's barely noticable. [Using a pair of shitty 680s and 2x 1080p 1x1440p]
You should be fine ^^
I actually had the same question. When I play DayZ, I want to have the map up on a second monitor (1440x900) and game on my main monitor (1920x1080) on a single GTX 760. I haven't bought my hardware yet for my PC so I can't tell you how it performs. But like Scia said, you should be fine.
