is it possible to have 2 monitors display the same thing? Instead of spreading your desktop out allowing more space to be used can you mirror what you do on the second monitor?
yes
no. i dont think so. unless theres some kinda compiz thing thatll do it.
yea it can be done. open nvidia control panel(if using a nvidia card) goto display > set up multiple displays > select the option "the same on both screens (clone)" option :-) enjoy
So panic would that make you have two mice?
jaja, cick right on desktop goto properties (or personalise), then goto advanced (or display settings) ull see both monitors, click 2nd monitor and enable, but make sure "extend my desktop to this monitor" isn't selected, then it will display same thing on both monitors, and no u don't need 2 mice lol
sonota, they both just show the exact same thing, so no, theres only one mouse
THANK YOU RAZE THE WORLD FORUM PEOPLE!!!111
yes do clone mode
