Dual Graphics Cards
Can you put two completely different graphics  cards in the same system and have them both run? I have no intention on having them run together to play games, just want to know if you can do it given the right motherboard and PS.
i used to have a gtx 680 classified and a gtx 560 to handle the 2nd monitor and physx it will work as long as you dont try to sli them, and have the power to handle it
I was thinking of a GTX 670 and an AMD card.
No that will not work. Well i've seen it done, but it was so finky it just wasnt worth it.
More hassle than its woth tbh.
