I recently ordered and received a level1techs KVM (2PC, 2 Monitor, 1.4DP, USB-C 10Gps). Unfortunately I have had just a heck of a time getting it set up correctly.
Where I’m at
- I have a personal desktop (Windows) and a work laptop (Macbook Pro) that I want to run on the same peripherals.
- The desktop is passing video signal through, but I can’t get the USB devices to work at all. The RGBs do not power on, and no signal seems to be getting past the KVM.
- Getting a macbook to work with a dock has turned into its own separate fiasco, so I’ve disconnected that side of the system for now.
A picture is worth a thousand words, so please see attached. Blue is currently connected, grey is currently disconnected (but planned)
What I’ve tried
- I’ve ordered and swapped out a lot of cables, including USB C 3.1 cables and USB C-to-A cables.
- I’ve tried connecting everything directly to make sure it works (can confirm for desktop. not so much for mac)
- Various USB ports on my desktop
- connecting a usb-c thumb drive to the desktop port in question (it works fine)
- at this point I’ve completely disconnected the PC2 inputs. I just want to troubleshoot PC1 in isolation.
I’m sort of running out of hypotheses on this one. Any ideas on what I could try?
Also, if you have any suggestions for Macbook Pro (M3 Pro) compatible hubs, I would be very grateful. I’m 0/2 right now.
Thank you for your time and consideration. Let me know if there are other details that it would be helpful for me to include.
