In past few months I had an issue where after cold start network connection works for few minutes and then stops (on both wired and Wi-Fi). Until recently simple restart was able to fix the issue, but in past few days.
I have tried changing cables, ports on a switch, connecting to not my home Wi-Fi but to Wi-Fi from my phone, checking different rj45 plug, memtest, disabling expo, dual boot between Manjaro and Windows, checking an Ethernet cable on my laptop and the same issue.
Other machines on my network don’t have that issue, so I started thinking that this is an MB issue and I need to buy a new one. But before I will bite a bullet - is there anything I can try?
PC specs:
MB: Gigabyte X670 GAMING X AX
CPU: Ryzen 7900x (ECO mode is on)
RAM: Kingston Fury Beast RGB, DDR5, 64 GB, 6000MHz, CL30 (KF560C30BBEAK2-64)
PSU: SilverStone Strider Platinum 850W (SST-ST85F-PT)
Cooler: Noctual D15
SSD: Kingston KC3000 2TB
