I’m looking into OC memory on a Threadripper platform. I don’t want to dive into this area too much and want achieve pretty standard goal of 3600 on 3200 rated RAM.
DRAM Calc sounds like a perfect tool for that, but I’m on Linux. I tried to run it with Wine but I’m not familiar with it and I’m getting a lot of unhandled exeptions. DRAM Calc is a portable app, not an installer. I can get GUI running but that’s it.
Is there another way of automatic calculation of memory timings under Linux?
There are some things Linux just doesn’t have, and I found the least painful solution is to install Windows on a small partition so I’ll be able to run tools such as DRAM Calc when I need to.
Wine Staging 6.0 and up is already good enough to run version 1.6.1 without additional tweaks. Any further than 1.6.1 is where it falls apart because it has a ring 0 driver it needs.
