DP1.4 KVM 3+ Monitors and 3+ PCs
Hey I’ve been looking for a DisplayPort 1.4 KVM.
I checked the store and it looks like there are some available for special order (I e-mailed Wendell late Friday) but if those don’t pan out does anyone else have any recommendations?
The only others I’ve found that meet my spec are these “Rextron” ones but I can’t find any place to buy them.
I purchased a KVM recently from “KVM Switches Online” but the “DisplayPort 2.0” switch described by their website has actually DisplayPort 1.2 when it arrived (I even paid $80 for overnight shipping, ouch!), now I have a > $1000 paper weight awaiting return.
It feels like buying a KVM with this kind of budget should not have to be this hard.
I have a 4x4 kvm I sell for $1200. 4 DP 1.4 inputs and 4 DP 1.4 console outputs.
I kind of have to interview customers because many customers don’t understand even things like Apple frowning on more than 2 monitors these days.
The biggest customers for these seem to be folks using two of the 8k displays that have dual DP inputs and for that use case it works well. It is not uncommon to need to use FIBRR fiber optic cables as well, esp. when using Literally All the DP 1.4 bandwidth.
There is no DP 2.0 chipset manufactured yet. And we might have a bit of delay seeing these kinds of chipsets because the production capacity is prioritized around the backlog of existing designs/products.
I don’t own or use any Apple products - not a fan of their business model, all my machines are Windows or Linux with most being Windows.
I have 3 monitors (the highest of which is a 21:9 3440x1440, 144Hz) and at the moment 2 PCs and a laptop (although it could end up being 4 when my additional work laptop arrives)
All I want is the easy ability to swap between these machines without having to deal with awful USB switches or manually plugging/unplugging Display Port cables. Since I have varied duties that all need isolation I can’t just consolidate as much as I would like to.
I just want the monitors to work normally when swapping, and have my primary desktop PC also be functional for things outside of work. I’m very unlikely to need anything past 4K60FPS for work, so the 3440x1440p144Hz is as demanding as it gets for a single cable.
I don’t anticipate needing fiber optic cabling for this, although if necessary I have no problems pickup additional hardware (I had to do that recently with a 40Gb fiber optic connection between two of my computers) as long as it doesn’t turn into the nightmarish hunt this KVM has been.
$1200 is less than I expected since I was just fooled into buying a DP1.2 product for > $1000.
Email me wendell at level1techs dot com and I’ll se you up and we can go from there
Hey @wendell, I actually emailed you prior to starting this forum thread, sent you a follow up not sure if it’s getting lost in the spam folder or something.
Will check, been traveling
@wendell is there a fiber dp cable you recommend?
Fibrr
Omg it has rgb…
Just what I need in my life.
Hi @wendell , I saw you mention fiber optic cables needed when doing the full DP 1.4 bandwidth over one of your KVMs. I happen to have one of yours (2 PCs 1 DP 1.4 monitor, USB 3.0) and I’ve noticed some occasional signal cutouts when using a G9 neo in HDR.
I wanted to ask, is there a length limit you’d recommend when using solely fiber optic DP 1.4 cables? You mentioned the total length of the cables shouldn’t exceed about 4 meters on your product page - is the limit the same for fibre optic cables or can they be longer than that?
Really appreciate the level of support you give for your wonderful products! You rock.
Fiberoptic matters less on cable length. Have ahd good luck with fibbr brand and generally should be ok.
Fw1008 on the g9 works as I use it
