I just got my new KVM hooked up and it is awesome! Display is working totally fine with all PCs tested. My expectation was, that the PCs wouldn’t know if I switch to a different PC with the KVM, but they do and switch their output accordingly. My misunderstanding I guess, but not an issue.
But sadly I have two issues remaining:
Audio has a constant low static. It is not so loud that I noticed right away, but if its a bit quite a really annoying problem. I guess the audio is not isolated enough inside the KVM, which is a total bummer. Is there anything I could do to help with the issue? Right now I can’t make use of the audio ports and that is a feature I wanted to use.
My second problem is with my mouse a Logitech G502 Lightspeed. The wireless works fine. But a wired connection does not work through the HID ports. The mouse is not recognized there. If I use the one USB3 port on the back it works as intended, but at first had some problem recognizing different button presses. Without hotplugging the mouse it seems to work fine over the USB3 port, but is a bit sporadic if I plug it out, in again and not reboot after. AND this blocks my only other backside port just for the mouse
I guess this is more an issue with my mouse, but maybe there is something that can be done to get it working on an HID port? If not it might be something to keep in mind for future revisions :3
I hope someone can give me some tips to solve these issues, but otherwise I am really happy with the KVM
