Hello I bought this game though Amazon and it forced me to use it through Steam and believe me I have checked the steam forums and they were of some help to me but I was hoping that someone here would be able to help me with my problem, here is what the screen said once I tried to start the game. Any help that you could give me would be great please describe what the help is don't just jot down a link and not tell me what it is for thank you in advance.
QA Timing INIT: 000244ms
D3BFG 1.1400 win-x86 Nov 9 2012 10:38:21
1596 MHz AMD CPU with MMX & 3DNow! & SSE & SSE2 & SSE3
3840 MB System Memory
256 MB Video Memory
Winsock Initialized
Found interface: {3492C928-4F22-4583-A530-749509785BDE} Broadcom 802.11g Network Adapter - 192.168.5.104/255.255.255.0
Found interface: {B913B1FA-EC18-4F74-847D-380576156694} Atheros AR8132 PCI-E Fast Ethernet Controller (NDIS 6.20) - 0.0.0.0 NULL netmask - skipped
Sys_InitNetworking: adding loopback interface
doom using MMX & SSE for SIMD processing
enabled Flush-To-Zero mode
enabled Denormals-Are-Zero mode
------ Initializing File System ------
Loaded resource file _common.resources
Loaded resource file _ordered.resources
Loaded resource file soundpc.resources
Loaded resource file soundpc_en.resources
Reading resource CRCs...
Current search path:
C:\Program Files (x86)\Steam\steamapps\common\DOOM 3 BFG Edition/base
C:\Users\Jaime\Saved Games\id Software\DOOM 3 BFG/base
file system initialized.
WARNING: Unable to open resource file maps/_startup.resources
----- Initializing Decls -----
Couldn't open journal files
execing default.cfg
couldn't exec D3BFGConfig.cfg
couldn't exec autoexec.cfg
----- R_InitOpenGL -----
Initializing OpenGL subsystem with multisamples:0 stereo:0 fullscreen:1
...registered window class
...registered fake window class
...initializing QGL
...calling LoadLibrary( 'opengl32' ): succeeded
X..WGL_EXT_swap_control_tear not found
display device: 0
DeviceName : \.\DISPLAY1
DeviceString: ATI Radeon HD 3200 Graphics
StateFlags : 0x5
DeviceID : PCI\VEN_1002&DEV_9612&SUBSYS_028D1025&REV_00
DeviceKey : \Registry\Machine\System\CurrentControlSet\Control\Video{9F3CD988-81F0-484E-8530-3369EA5C13C0}\0000
DeviceName : \.\DISPLAY1\Monitor0
DeviceString: Generic PnP Monitor
StateFlags : 0x3
DeviceID : MONITOR\CMO1558{4d36e96e-e325-11ce-bfc1-08002be10318}\0001
DeviceKey : \Registry\Machine\System\CurrentControlSet\Control\Class{4d36e96e-e325-11ce-bfc1-08002be10318}\0001
dmPosition.x : 0
dmPosition.y : 0
dmBitsPerPel : 32
dmPelsWidth : 1366
dmPelsHeight : 768
dmDisplayFlags : 0x0
dmDisplayFrequency: 60
...calling CDS: ok
display device: 0
StateFlags : 0x5
StateFlags : 0x3
dmPosition.x : 0
dmPosition.y : 0
dmBitsPerPel : 32
dmPelsWidth : 1280
dmPelsHeight : 720
...created window @ 0,0 (1280x720)
Initializing OpenGL driver
...creating GL context: failed to create OpenGL 3.2 context
created OpenGL 2.0 context
succeeded
...making context current: succeeded
------- Input Initialization -------
Initializing DirectInput...
mouse: DirectInput initialized.
keyboard: DirectInput initialized.
freespace_version: 0.6
0 freespace devices
OpenGL Version: 2.1
OpenGL Vendor : ATI Technologies Inc.
OpenGL GLSL : 1.3
...using GL_ARB_multitexture
X..GL_EXT_direct_state_access not found
...using GL_ARB_texture_compression
...using GL_EXT_texture_compression_s3tc
...using GL_EXT_texture_filter_anisotropic
maxTextureAnisotropy: 16.000000
...using GL_EXT_texture_lod_bias
X..GL_ARB_seamless_cube_map not found
...using GL_ARB_framebuffer_sRGB
...using GL_ARB_vertex_buffer_object
...using GL_ARB_map_buffer_range
...using GL_ARB_vertex_array_object
X..GL_ARB_draw_elements_base_vertex not found
...using GL_ARB_fragment_program
X..GL_ARB_uniform_buffer_object not found
X..GL_EXT_depth_bounds_test not found
X..GL_ARB_sync not found
...using GL_ARB_occlusion_query
X..GL_ARB_timer_query not found
X..GL_EXT_timer_query not found
X..GL_ARB_debug_output not found
--------- Game Map Shutdown ----------
0: Speakers (Realtek High Definition Audio)
2 channels, 48000 Hz
Front Left and Front Right
Default Console Device, Multimedia Device, Communications Device, and Game Device
Using device 0
ERROR: GL_ARB_draw_elements_base_vertex not available
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
