Hey all!
I’ve had these included in a few boards/cases, I’ve never used them as they never seem to fit. Anyone else use them?
Hey all!
Not any more! there a pita!
Cheers for confirming,tried one and it was a pita!
The plastic standoffs are useful if your motherboard has a mount point but the case does not have a matching one - you can snip off the bottom of the plastic standoff and put it into the motherboard point, and it will just rest on the case backplate for a bit of support.
Ahhh good call
I was thinking it would only work if you snipped it, but I thought that was just me being stupid!
