Does anyone know how to flash bios?
I'm a noob and I need to flash my BIOS. Help. It's a P5K Deluxe.
i. Go to the manufacture's website and download the latest bios for your motherboard.
ii. Burn it into CD
iii. restart your PC
iv. At post, press the key to go to your mobos BIOS
v. At the Cmos feature, make the 1st boot = CD drive, and make the 2nd boot = HDD
vi. Exit and save
vii. make sure you have your burned .iso cd in your cd drive
viii. follow the instruction.
Thats it!!!
Just to make sure call the mobos manufacture number, and ask them how.
Good Luck
OK thanks.
works with a USB stick as well.
I used a stick to update mine.
i used my big external hdd before. LOL
Pamplemousse wrote 6 minutes ago »
USB stick is not safe(kind of). You would brick your mobo if that USB stick got disconnected.
Can it be dvd? Because i don't have blank CDs.
sure, but that's like a 2MB or less file for ONE dvd lol.. it works though.
k thanks cuz XP isn't recognizing my damn blank cds.
yea just sit there and pray nothing happens while you're flashing the bios.
kk thanks I don't believe in god so I can't really pray lol. Maybe I'll pray to the Jim Caviezel.
123456iambelial wrote 7 minutes ago »
ya if it gets disconected lol.
the P5K mobo is easy as hell to flash, read the manuel there's like a easy flash something built in the BIOS, I always use a stick it's way more simple
ultracombo wrote 31 minutes ago »
lol pray/hope/etc, you know what i meant.
