I know USB4 devices are very new, hence uncommon, so I may not get a reply. Fingers are crossed
I’m at the point in coding an IOMMU parser where I need data I can’t get from my own hardware. Once I have the needed info I’ll post an UPDATE: section here so folks know it’s handled and another one when I have a github link to the working script.
Request:
If you have a system with:
- Thunderbolt bus (don’t need Thunderbolt 4, 3 should do fine)
- USB4 device(s) (any should work, net, storage, whatever)
- (optional) Thunderbolt HUB
Run these 2 commands (just doing this and not #2 or #3 is still very useful):
A.
echo "# 1.A" > ./1a.txt; ls -aFld /sys/bus/thunderbolt/devices/* >> ./1a.txt
B.
echo "# 1.B" > ./1b.txt; ls -aFld /sys/bus/usb/devices/* >> ./1b.txt
NOTE: Make sure thunderbolt and USB4 dev are bound to the host (might need to
echo 1 > /sys/bus/pci/rescan
) … ie, don’t leave them attached to a running VM -
If you have one, attach the USB4 device to a lower generation USB-C port (ie, USB3.2 or earlier) (I don’t know if USB4/Thunderbolt mobos have lower speed USB-C ports)
A.
echo "# 2.A" > ./1a.txt; ls -aFld /sys/bus/thunderbolt/devices/* >> ./2a.txt
B.
echo "# 2.B" > ./2b.txt; ls -aFld /sys/bus/usb/devices/* >> ./2b.txt
(optional) if you have a Thunderbolt dock, plug it into the Thunderbolt USB-C port and then attach the USB4 device to it (even better, also attach a USB3 or earlier device to the dock at the same time)
A.
echo "# 3.A" > ./3a.txt; ls -aFld /sys/bus/thunderbolt/devices/* >> ./3a.txt
B.
echo "# 3.B" > ./3b.txt; ls -aFld /sys/bus/usb/devices/* >> ./3b.txt
Take whatever results you have (files: 1a.txt, 1b.txt, etc) and submit them to me in whatever way is most convenient. A pastebin link reply here is great. Or a PM here. Or if you want, PM me and I’ll send you my email address and you can send me a .zip or .tar.gz archive.
What I’m looking for is the sysfs symlink path to each device, along with that device name, so if you see a bunch of stuff that seems extra in the symlink … it actually is needed.
Background:
I’m working on a script to associate attached devices by IOMMU grouping.
I’m at the point where I can output groups like this:
➤ group: 20
└── 08:00.1 <USB> "Matisse USB 3.0 Host Controller" (AMD) [1022:149c]
└── usb1 <usb> "xHCI Host Controller" (Linux kernel) [1d6b:0002] {1:1}
├── 1-1 <usb> "ITE Device(8595)" (ITE) [048d:8297] {1:2}
│ ├── 1-1:1.0 <usbhid>
└── 1-6 <usb> "USB2.0 Hub" [05e3:0608] {1:4}
└── 1-6.1 <usb> "Patriot Memory" [13fe:1f00] {1:10}
└── 1-6.1:1.0 <usb-storage>
└── disk: sdk <iso9660> "label=ISOIMAGE"
├── part: sdk1 <no filesystem> "type=Microsoft basic data"
└── part: sdk2 <vfat> "type=EFI System"
(ie, associated tree of IOMMU > PCI > USB > USB Device > Block Device > partitions)
I’d like to get this working with USB4 and Thunderbolt but … I have neither. The code should be mostly the same as how I parse /sys/bus/usb but I would like to see actual working examples to be sure I haven’t missed something in the way the structure is attached/named.
