pls answer
thanks
pls answer
thanks
Yes. Check Logan's new video. It uses the new 1150 socket. If you happen to have planned to upgrade from sandy/ivy, you're basically screwed.
oh man, its so easy to build a computer -.-
Building a computer isn't that hard ;P The very ungifted people at most PC stores get it together, not nicely, but it works somewhat :D
Ya LGA 1150 is required for a Haswell CPU [AND GOOD COOLING! they get insanely hot]
Well if you on Z77 ivy bridge right now, there is realy no point to upgrade to hasswell. For gaming. Cause there is not much of an improvement. also hasswell runs extremely hot, you indeed need a new mobo for hasswell socket 1150.
