ALRIGHT.
So very recently some stuff happened and I no longer have a functioning rig. I do have a laptop with an i3, but I really miss being able to actually run games above 800x600. I'm still in the process of planning, but here is what I'll be dealing with.
Dell Inspiron 3452
i3, 4GB (8GB soon), 500GB HDD (will be ssd soon)
Pretty much just a laptop I've had for a few months, got it pretty cheap but it can do basic things I need. It's also all I have right now.
EVGA GeForce GTX 960 4GB (mini-ITX)
Usual GPU specs, needs a 6-pin PCIe cable, 125w~ TDP
Bought it off a friend for around $100, works pretty well. Used it on his rig. I got the mini-ITX version on purpose as well. It's only 6.8" long, so it won't take up a lot of space or be an eyesore.
Now for the Adapter...
$8.75 without shipping
Just to help visualize this better i'm throwing in pictures. I have no idea if this is enough for the card. What I guess I'll be doing is putting the end piece where my Wireless Adapter Card is and just use Ethernet.
$24.99 with local pickup, 3.25" x 6" x 1.6", 220w, 40mm Fan
So this is a pretty tiny power supply. It supplies enough for the graphics card and does what I need it to.
Additional Supplies
2 SATA male to Molex female $5.52 - Power supply only has 2 Molex (used for used for PCIe adapter). Both will be used for the 120mm Fan and the PCIe Express x1 to x16
- 1 Molex x2 to 6 pin PCIe Graphics Card Adapter $2.99 - Need it for GPU, should work just fine
- 1 Fractal Design 140mm Case Fan $19.99 - I've had it lying around for a while so I'm finally using it for something. I'm planning on putting it in the front of my masterpiece.
Total Cost: $48.65 ... Includes how much I still need to finish this
HOW WILL THIS WORK?
- 1: Place GTX 960 in the PCIe Express x1 to x16 adapter
- 2: Connect Power Supply's 2 Molex with the 2x Molex to PCIe 6 pin adapter and put it in GPU
- 3: Connect both Molex to SATA adapter into power supply and the other end, Fan & PCIe x16
- 4: (HELP) Put together a switch to power on the power supply when laptop powers up
- 5: (HELP) Find/Make a case to close this together in
- 6: Replace WiFi card with PCIe x1 adapter and use Ethernet (Or use a USB WiFi stick)
WHAT DO I NEED? (will check off once dealt with)
- (BIG) Will this actually work? Am I missing some details?
- How can I find something to enclose this in? I don't have a 3D printer for fancy tools
- Need something compact, will include concept art below
- How can I deal with extra cables? (Cut cables, insulate exposed wire?) Needs to be small
- How can I put together a mechanism to have this turn on when the laptop powers on?
- What am I risking here, what am I missing that will screw me up?
MS Paint Concept "Art"
Thank you all for your support, it means a lot to me
EDIT 1: Spelling
EDIT 2: Professional Concept Art
