Terve!
A friend of mine has a Fury X that constantly overheats. After some checking I found that the pump on the AIO Cooler has a mechanical defect (makes noises when plugged into 12V, but doesn’t pump any water).
Just for the hell of it, I’d like to ghetto mound an AIO Cooler for a CPU on that GPU. It seems like the holes are fitting, but I am having trouble getting the VRM Cooler off the reinforcing Metal plate.
Here’s a picture of the cooler, I am talking about the copper thing on the right of the actual pump/GPU cooler thing.
Unfortunately, you cannot. The cold plate was specifically designed to work with he raised HBM memory on the die. Any ol’ AIO will not work. You risk severely damaging it.
You would have to buy the exact same cooler directly.
There is just one problem with that: Getting all of the parts required to get the card in working condition again will set you back more money than buying a new GPU.
Alternatively, write an email to https://www.arctic.ac and ask if their Accelero Xtreme III or Xtreme IV works on the FuryX. Rajintek has the Morpheus II, lists the R9 Fury as supported, would have to ask them if the FuryX is supported too.
Changing over to an air-cooler will be a lot cheaper than replacing the watersetup.
Terve!
Personally I don’t know if it will work. What I saw is that the GPU itself has a cutout in the Copper plate going over the rest of the card. (an there’s some kind of plate under the AIO itself, so anything flat should do the trick)
My plan is to ghetto mound something onto the GPU and use a cooling fin (or two) on the metal plate that acts as a heat spreader for the rest of the card.
If I see it not working I’ll integrate it with my other PCs liquid cooling loop and use the stock cooler equipped fury in that PC. It’s more of a passion project for me tbh.
Thank you for the info though.
Sayonara!
Shadow
worst comes to worst if you know someone who is skilled in cnc milling machines if you take accurate measurements (or take the component to them) they can probably custom mill your cooling plate out of copper and solder the tubing and cover plate on it for you.
That thing is a fucking monster and with two high quality fans mounted it is very quiet for 300W cards. My Vega64 is not hitting 70°, not even in heavy stress testing.
Peeps in this thread really need to go look up what GN did with their Vega FE - they used a regular AIO CPU block and got great results out of it.
The HBM + Die on Vega (and presumably also Fury) and Radeon 7 doesn’t even make great contact with the stock heat sink due to differences in height. Having a CPU cooler that is convex in the middle may even help that if it has some flex in it (so long as it doesn’t crack anything ).
Either way, GN got great results.
edit:
the only mods GN needed to do were with regards to drilling mounting holes in the cooler mounting (or maybe they made their own, i forget) for the vega hole spacing - it is different to CPU mount spacing.
Terve!
The Rajintek cooler is ordered, should arrive today. I soldered some cables together to have a VGA to 4 pin fan adapter.
I’ll upload pictures if I remember.
Sayonara!
Shadow
Edit: I didn’t go for the AIO in the end because the PC I am planning on using the GPU in doesn’t really support that and I don’t have an AIO lying around to try.
Terve!
As requested I shall post the pictures. Results are still pending since I haven’t fully tested the GPU yet (3D Mark got it up to a temperature of 72°C).
If there are any admins that cam make the pictures into thingies, please go ahead.
First off: the constructed adapter:
Hello
Well, it’s abeefy tripple slot card, but it works like a charm.
I considered putting in a second air cooled Fury X, but I don’t have the space for it.
Sayonara!
Shadow
Edit: make sure you get the morpheus II, not the morpheus apparently that one doesn’t fit.
