Hi folks,
I know this is a common topic around these parts but I’m finding the current crop of Z690/Z790 motherboards fairly lacking in expandability. I got a good deal on an i5-13600K and I’m looking for a decent board to pair it with that has a full complement of expansion slots. I’m willing to live with the fact that most of them will be x4 or x1, connected through the PCH, but I would like at least x8-in-x16 and x4-in-x16 slots connected directly to the CPU.
The best candidate so far is the Asus Prime Z690-P and Z790-P, which have the primary Gen5 x16 slot and three Gen3/Gen4 x4-in-x16 slots connected through the PCH. Unfortunately one of the latter is tucked right under the former, rendering it essentially unusable when a two-slot graphics card is installed. And it doesn’t split out its PEG lanes to a second slot.
Anyway, this is more “old man yells at cloud” than anything else, but I thought I’d ask around for suggestions. I know Wendell has mentioned a few boards that have one slot split out from PEG lanes at the bottom (that runs at a slower speed so it doesn’t need a redriver/retimer) but I can’t seem to find them. I have an H670 board that I can use in the meantime until better options hit the street.
Thank you!
- DDR4-3200 4×16GB
- Peripherals
- Two-slot GPU (Gen4 x16, willing to live with half bandwidth)
- 10GbE NIC (Gen3 x4, can’t use a built-in e.g. Aquantia NIC due to lack of SR-IOV)
- SAS HBA (Gen3 x8, willing to live with half bandwidth)
- [FUTURE] Thunderbolt AIC (Gen3 x4) or built in
- Renesas USB 3.0 (Gen3 x1) or built in (must support device reset)
- Second GbE NIC (Gen3 x1) or built in
- Around $200 (lol, I know, but a $500 “creator” motherboard is a non-starter even though it may meet all or most of my requirements)
