Gooood morning, everyone!
Have you ever wanted to use an awesome, fresh Linux distribution like Solus, but were afraid you wouldn’t have the support you needed? Wanted to kick bubblegum and chew ass, but you’re all out of… ![]()
Anyway, Solus is an operating system for developers BY developers.
“Don’t they all say that?”, yes that’s true. However, with Solus you may find that’s actually the case. Developers aren’t burdened with looking up commands to add repositories or to install their favorite SDKs or IDEs. There is a graphic manager that does it for them, and common environments like Ruby, Node, and OpenJDK are installed by default.
What about Developer Operations?
That part was a tiny bit tricker, and required a little more work. But, let’s be honest, you’re not in DevOps because you’re annoyed with the Terminal ![]()
Chef
Chef was definitely a tough one to figure out. Fortunately, the solution is via .deb packages.
Head over to the Chef DK web site and download the .deb package for the Debian Stretch DK.
Once there, head to your download directory. We’re going to use the ar command to extract the .deb package.
ar vx chefdk_3.2.30-1_amd64.deb
Three packages come out of that. Throw the data.tar.gz into /opt
sudo tar zxvf data.tar.gz -C /opt
You can throw the control.tar.gz in /opt too, but make it a different folder (like ChefAdmin or something).
sudo tar zxvf control.tar.gz -C /opt/chef_admin
Head over to the chef_admin directory and (with sudo) run postinst
cd /opt/chef_admin && sudo ./postinst
You’ll get:
Thanks for installing Chef DK!
Hm… Is it true?
Move on over to where you’ll house your cookbooks. For me, it’s ~/Projects/Scripts/Chef/cookbooks. One thing to remember is you’ll need your .chef directory in the root of where your working (in my case, Chef/.chef). I created the knife.rb file and got my key from the Chef server. If you’re making one from scratch versus downloading one, this is all you need:
current_dir = File.dirname(__FILE__)
log_level :info
log_location STDOUT
node_name "chris"
client_key "#{current_dir}/chris.pem"
chef_server_url "https://chefserv/organizations/admindev"
cookbook_path ["#{current_dir}/../cookbooks"]
Alright, well, let’s test this bad boy out.
chef generate cookbook nginx
No error, let’s see if the upload works
knife upload cookbook cookbooks/nginx
Verify on the Chef Server
Nice ![]()
Terraform
Terraform was the easiest of all tools to setup. Download from the website, extract the archive, and move the executable to /usr/bin or /opt (be sure to create an alias or PATH for the latter).
Test with terraformor terraform version
admindev@battlestation ~ $ terraform
Usage: terraform [-version] [-help] <command> [args]
The available commands for execution are listed below.
The most common, useful commands are shown first, followed by
less common or more advanced commands. If you're just getting
started with Terraform, stick with the common commands. For the
other commands, please read the help and docs before usage.
Common commands:
apply Builds or changes infrastructure
console Interactive console for Terraform interpolations
destroy Destroy Terraform-managed infrastructure
env Workspace management
fmt Rewrites config files to canonical format
get Download and install modules for the configuration
graph Create a visual graph of Terraform resources
import Import existing infrastructure into Terraform
init Initialize a Terraform working directory
output Read an output from a state file
plan Generate and show an execution plan
providers Prints a tree of the providers used in the configuration
push Upload this Terraform module to Atlas to run
refresh Update local state file against real resources
show Inspect Terraform state or plan
taint Manually mark a resource for recreation
untaint Manually unmark a resource as tainted
validate Validates the Terraform files
version Prints the Terraform version
workspace Workspace management
All other commands:
debug Debug output management (experimental)
force-unlock Manually unlock the terraform state
state Advanced state management
AWS-CLI
This is as hard as you make it. I use Pip to set it up (note, I have an alias for pip to run pip3 – PYTHON 2 IS DEAD TO ME AND I ALWAYS HATED IT SO THERE)
pip install awscli --upgrade --user
After the command completes, check ~/.local/bin for aws. Once you confirm that’s there, export that path to your $PATH via cli or in your ~/.bashrc or ~/.bash_aliases
export PATH=~/.local/bin:$PATH
Check the command:
Now, we dance ![]()
I would love to hear the experience you guys had with Solus. Or, if there are any tools you as a community want to see running on Solus, maybe fire up a thread or post here and we can come together to see what works.
@oO.o @'ing you because you said so ![]()
