The user, in their own words: I am jazzed to be participating, but, I am not really participating in the way the organizers intended, so I would like to opt out of the prize pool. I feel this is the right thing to do since we are encouraging users to learn and not vibe code. Claude ULTRA isn’t exactly rolling up your sleeves and writing code.
- Start date: this project began on October 10th, 2026, 24 days before the Devember 2026 Home Lab Edition post went up (November 3rd). This write-up covers October 10th to November 1st. The project continues through Devember; later posts will cover the Devember window on its own.
- AI use, in full: the lab is operated by Claude Code (Anthropic’s agent CLI) running on the user’s desk machine under the user’s supervision. Claude runs the commands; the user approves each state-changing one at a permission prompt. Models used in the span, as recorded per session: Claude Opus 5.5, Opus 5, Opus 4.8, Sonnet 5.5 and Fable 5.1; Fable 5.1 is the standing model since November 2nd. A claude.ai Project received scrubbed review packs for second-opinion reviews; Remote Control from the user’s phone was used from October 29th. A local open-weight model (a 35B mixture-of-experts) runs on one of the lab boxes for research jobs, in a sandboxed VM.
- This post was written by Claude, from the project’s git history (948 commits), its decision log, its audit findings and the session transcripts, under the user’s direction and correction. Every number is from that record; nothing is from memory. The user edits the final text.
- Not vibe coding, by design: the whole point of the project is the opposite. Every command is read before it runs, every design decision is the user’s and recorded with what risk it accepts, and Claude’s mistakes are audited and counted (section 6).
Scorecard
| Measure |
October 10th to November 1st |
Days |
23 (19 active) |
Sessions / user messages |
126 / 2,538 |
Commits |
948 (17 % fixes or reverts) |
Spent |
$970 hardware (C5 $600 + second GPU $200 + AP $170) + the Claude subscription, stepped $20 → $100 → $200 a month |
Built |
firewall migrated · 7 VLANs · secrets broker · logging + dashboards · local-model agent VM · honeypot |
Times the user had to push back |
27 named fights; 86 of 1,648 typed messages carry a correction (5 %) |
Claude-induced incidents |
11 major in 20 days (~15 h), ~25 small |
Sessions with zero corrections |
75 of 119 |
Anthropic “cyber” policy stops |
16 refusals in ~11 incidents, all on ordinary lab admin |
1. What the user started with (October 10th)
The user, in their own words: Fortunate to have gotten a decent amount of enterprise E waste to play with.
In service on day one
| Box |
Hardware |
Role |
| Firewall (old) |
Simply NUC Topaz (NUC11i5TZ): Core i5-1135G7, 16 GB, Samsung 860 EVO 250 GB M.2 SATA, Intel I225-LM 2.5 GbE + I219-V |
OPNsense with Suricata; an unused 2 TB SATA SSD inside it |
| ISP gateway |
The ISP’s Wi-Fi 6 gateway |
Routing and the house Wi-Fi; later an AP only, then off |
| C1 |
ASUS VivoBook S15 (S533EA): Core i5-1135G7 (4C/8T), 8 GB, 512 GB NVMe, Intel AX201 Wi-Fi 6 |
Kali; the admin workstation |
| C6 |
Simply NUC NUC8v7PNF (fanless): Core i7-8665U vPro (4C/8T), 64 GB DDR4 (2x 32 GB), Samsung 870 EVO 250 GB SATA, M.2 slot empty, Intel I219-LM + internal RTL8153 USB gigabit, Intel Wireless-AC 9560 |
Kubuntu; the user’s desk machine, where Claude runs |
2. What was bought
The user, in their own words: Again, this isnt about spend, its not about who has the best hardware or the best AI tooling, so I want to be transparent about spend.
- The C5 box: a used Alienware Area-51 R2 with one GTX Titan X 12 GB, $600. Came with 16 GB; four DDR4-2666 sticks bought in 2022 for another box took it to 64 GB on day 11.
- A second GTX Titan X 12 GB, $200, plus two genuine Dell GPU power leads, arriving just after this window. The whole local-model box, 8 cores, 64 GB, two 12 GB cards: $800 plus RAM paid for in 2022.
- GL.iNet Flint 2 (GL-MT6000), $170, ordered October 22nd, arrived the 23rd: the AP and, for now, the VLAN switch, on upstream OpenWrt. Claude’s recommendation, reversing the “use the NETGEAR R6260 already on the shelf” decision of six days earlier. Two weeks later the lab’s Intel Wi-Fi 5 clients were still fighting it.
- The Claude subscription: started on Claude Pro at $20 a month, moved up to the $100 tier, then to the $200 tier, which is where it runs now. The quota wall hit at every tier (section 7). One month at the top tier costs more than the AP.
- Hardware spend in the window, C5 and the AP together: $970. Plus the subscription, $20 → $100 → $200 a month.
- HPE Smart Array E208i-a for the DL160, ordered before the project, arrived the 23rd; parked with the DL160.
3. What got built (day numbers count from October 10th)
The user, in their own words: We did get a bit done, this was what inspired me. I had all this stuff, but I didn’t want to spend the countless hours learning and troubleshooting, did Claude save me any time? We are gonna find out through this project, maybe.
Firewall
Day 2: management lockdown (admin from one host, anti-lockout off, TOTP on GUI, sudo and console).
Day 15: firewall migrated from the old NUC to C2; the user did the cutover by hand from Claude’s runbook (two drafts, section 6). Old box earmarked for a honeypot.
Day 19: daily age-encrypted config backups by timer, a backup before every write, ZFS boot environments (newest 10 kept).
Day 21: ProtonVPN over WireGuard as the default gateway for trusted and compute, fail-closed, one-command off/on. A bypass alias for two hosts (built as permanent; the user meant a switch, see section 6).
Suricata on every segment and the WAN, all eve output shipped off-box (~1 GB/day); a display-only console dashboard on the firewall’s screen.
The TV allow-listed to YouTube only; the live ruleset (37 lab rules) recorded with a drift check; a self-closing 60-min egress window for the management segment.
Segmentation
Day 15: Flint 2 on upstream OpenWrt from a built image: key-only SSH, no LuCI, no packet filter, DSA trunk. Day 17: ISP gateway Wi-Fi retired.
Days 16 to 22: VLANs for trusted, compute, IoT, media, management, work (the work laptop: watched passively from the firewall side, never touched) and display (TV Pi). Client isolation by default; only trusted opens connections to the others.
Camera egress allow-list built; the cameras’ upload behaviour is still being studied before it is enforced.
Logging and observability
Day 21: rsyslog store on a USB SSD at C6, per host per day, C4/C5 pulled every 5 min, the work laptop’s lines withheld.
Day 22: Grafana + Prometheus + Loki in a VM on C5, node exporters on firewall and AP, Alloy from C6. Day 23: TV dashboard on the touchscreen Pi, kiosk, read-only viewer.
Wazuh installed and retired inside 24 hours.
Compute and AI
Day 10: honeypot Pi with OpenCanary. Day 11: C5 imaged over PXE from C6’s own imaging segment; memtest86+ overnight (6 passes, 0 errors).
Day 19: C5 as AI host: llama.cpp with CUDA on the Titan X, six local models, a root-owned control tool and desktop icons so the user runs it without Claude.
Day 20: an internet-enabled agent VM on C5 behind its own nftables wall: local 35B mixture-of-experts model, local SearXNG, open-source coding agent with full tools, nightly job queue, all visible on the desktop.
Day 22: C5 re-planned as VM host: agent VM pinned to three cores, lab VMs on a routed subnet, LVM on the 2 TB SSD.
Records
~200 backlog rows from the user’s own words; 160 decisions recorded verbatim; 41 dated findings; a close-out every session; a hardware register of ~40 assets with a baseline per host.
4. The open-source stack
The user, in their own words: We like open source, we want to use it.
Local, open-source and self-hosted first; the cloud only where it was decided and written down. In service unless marked.
- Firewall: OPNsense: pf, Unbound with every segment’s queries logged, Suricata with the ET Open ruleset, WireGuard for the VPN gateway, syslog shipping, ZFS boot environments for rollback, a metrics exporter.
- AP and switch: upstream OpenWrt from the lab’s own image, WPA3 where the clients support it, the DSA switch carrying the VLAN trunk, key-only SSH, no web UI, no packet filter by design.
- Operating systems: Kubuntu, Ubuntu Server and Desktop, Kali, Raspberry Pi OS and Debian on the Pis; KDE Plasma or GNOME on the desktops; GrapheneOS on the phone.
- Host security: nftables and ufw as host firewalls, sudo-rs with exact rules for the agent account, auditd, fscrypt and LUKS for the disks.
- Records: git with every file encrypted at rest and a redact filter, gitleaks on anything leaving the box, age for backups, ssh-audit on every sshd, Ansible for the guardrail package. The lab’s own tooling is Python and shell, in the repo.
- Imaging: PXE from a segment on C6 with Ubuntu autoinstall and cloud-init seeds, plus a manual-install entry for anything holding credentials.
- Logging and observability: rsyslog, Grafana, Prometheus, Loki, Alloy and the usual exporters; a Firefox kiosk on the TV Pi.
- Virtualisation: KVM/QEMU with libvirt on C5, a routed and isolated VM network, LVM.
- Local AI: llama.cpp with CUDA serving open-weight models (dense and mixture-of-experts, 9B to 35B), SearXNG for search, OpenCode as the agent in its VM, pueue for the queue.
- Security tooling: OpenCanary, OpenVAS, nmap, memtest86+, f3 (which exposed a counterfeit 2 TB USB stick), smartmontools.
- Tried and dropped: Wazuh (one day); a tmux-based launcher.
- Decided, not yet built: T-Pot on the old firewall box, Frigate for the cameras, a time-boxed mitmproxy test on one camera, Home Assistant later.
- Not open source, named for honesty: Claude Code and the models behind it; NVIDIA’s driver; the camera vendor’s app and firmware; the TV; the ISP gateway’s firmware; Proton’s services (open-source clients, closed service).
5. Time
- The user did not track their own hours. The session record is what there is.
| Measure |
Value |
| Calendar span |
23 days, 19 active |
| Sessions |
126 (3 on day one, 27 on October 31st) |
| Messages from the user |
2,538 (1,648 typed, the rest pasted output) |
| Commits |
948 (6 on day one, 114 on October 31st); 17 % fixes or reverts |
| When |
85 % of commits between 09:00 and 21:00 local |
| Tokens |
October 31st alone wrote 19.7 million cache tokens |
6. When the user and Claude fight
The user, in their own words: This robot and I fight, a LOT.
An agent that runs a network at machine speed is also wrong at machine speed. What makes it workable is a record that can be audited. This is the audit, in full.
In the user’s words, as recorded at the time:
“IF YOU CAN CHECK, CHECK, DON’T GUESS.” (October 26th)
“I want the oversight, I do not want the overhead.” (October 22nd)
“I know you love to blame my hardware but it’s usually bad code or config we made.” (October 29th)
“Would you look at that, it was CLAUDE the WHOLE TIME!” (October 30th)
“You DOS’d us, again.” (November 1st)
Claude wrong, the user right, and the user had to push
Twenty-seven entries, each from a dated finding or the user’s recorded words, grouped by what went wrong; the date is the day it happened.
Guessed when it could have checked (8)
Oct 19. Quoted a distro signing-key fingerprint from memory (the old key), raised a false “mismatch” alarm; the Pi build took three reflashes. ~5 h.
Oct 22. Stated C2 had one NIC, from one grep; the baseline Claude had written listed three. User: “why can’t you keep track of the hardware in these devices?”
Oct 22. Firewall GUI menus described from training data, wrong “all the time”. Fix: pull the vendor docs at the installed version before describing any page.
Oct 26. Escalated “memtest C2, priority 1” when the record held the memtest from four days earlier and the user’s “C2 is fine”. User: “check on that before you send us chasing things we already did.”
Oct 26. One day: guessed a POST halt, guessed a PXE boot order, invented a DHCP config section, gave a false all-clear from a grep that had failed for lack of sudo. User, in capitals: “IF YOU CAN CHECK, CHECK, DON’T GUESS.”
Oct 28. Rebuilt what an existing tool already did (user: “you look to be reinventing a wheel”); stated the C4/C5 Wi-Fi cards from one grep (“I know we have specs on that hardware”); blamed C6’s Wi-Fi card when the only change was the AP (“we don’t change from one AP to another AP then start blaming this device”). User: “stop half assing my sessions.”
Nov 1. Firewall GUI pages described wrong three times in one evening.
Nov 1. Asked the user to run ls on directories Claude could read itself. User: “how many times. Go look. I want a number, and then I want an answer on WHY IT KEEPS HAPPENING.”
Blamed the hardware (2)
Oct 28 to 31. Copy and paste. Selecting text in Claude’s terminal stopped working. The user pointed at Claude as the cause 7 times in four days. Claude was wrong 11 times: blamed tmux, the terminal emulator, the laptop, a hotkey, C6’s Wi-Fi; said “wait for an update”; restored a setup the user had asked removed; suggested Shift-drag 46 minutes after the user reported Shift-drag failing. The cause: Claude Code’s own renderer, fullscreen with mouse capture, copying via a clipboard path its account couldn’t reach. User: “Would you look at that, it was CLAUDE the WHOLE TIME!”
Oct 29. C5’s Wi-Fi blamed on the card (sticky PCIe error bits), antenna adjustments proposed before a build audit; the AP’s beamforming was the cause. User: “I know you love to blame my hardware but it’s usually bad code or config we made.”
Broke something (9)
Oct 20. AP setup script with the wrong address form, run on the wrong host; flushed C6’s IPv6 link-local in passing.
Oct 25. Asked to format a USB stick, zero-filled it first. User: “did I say zero fill it?” The killed dd hung the stick.
Oct 25. Shipped a host kit as git-crypt ciphertext. An hour at the bench. User: “goatrope”.
Oct 26. A 120-character one-liner wrapped into two commands on the laptop; C5 lost its default route after a cable pull (Claude’s config left the wired route in place); a firewall alias changed but never reloaded, so the work laptop “had no internet”. Three self-inflicted problems in a day.
Oct 26. Rebooted C5 without warning; the user lost the KVM view. User: “we need way better communication about you rebooting boxes.”
Oct 28. C5 had no keyboard at the login screen after a --no-install-recommends install dropped the input driver.
Oct 28. The lockout. The session launcher’s exit trap locked the encrypted vault under a live session. Five launchers stacked, each with a guard loop still running; Claude’s sign-in screen redrew in a loop, hundreds of duplicate lines. The user opened a second Claude session as themselves, with no project context, to find out what had happened. Claude’s first proposed recovery failed; user: “swing and a miss.” Result: one launcher, a tested recovery script, and a rule that anything the user depends on gets tested across two sessions first.
Oct 30. Suricata pointed at its own log stream; alerted on itself at 14 MB/s for ten minutes.
Nov 1. Two self-inflicted outages in one afternoon. A display-off test with no recovery armed; then a Wi-Fi driver reload on the box Claude itself runs on, which cut the link until the user rebooted. User: “You DOS’d us, again.” Rule since: before any test that can cut the link, arm an independent revert on a root timer that fires even if the session dies, stated in the same message as the test.
Lost the thread of the record (4)
Oct 12. Ran git crypt status and a git config read straight past two deny rules without noticing. Self-reported later.
Oct 21-22. Built the firewall cutover runbook on a stale brief (“management stays on the laptop”, “Claude read-only”) when the written decisions said the opposite. User: “you may be way confused, pull the whole context, review your work.” Two drafts cost ~3 % of the weekly quota.
Oct 23. Refused to run a script on the right box because of a hostname case comparison in its own code; then misread the order of work just given.
Oct 31, found Nov 5. The user asked for a “cut out” so two hosts could reach sites that block VPNs. Claude built them permanently off the tunnel and verified it as done. The intent, said when the forum draft exposed it: both on the VPN by default, with a switch for when they need to avoid it. Three days of Claude’s own session traffic went out the house WAN, and the user learned it from the draft.
Left the user out of the loop (4)
Oct 29. The first local-agent job ran headless on C5. User: “I want full visibility on this C5 box, I want to be able to run it independent of you, and I want to SEE EVERYTHING that’s happening on it.”
Oct 29. Three decisions buried at the end of a long report, then a build in the same turn. User: “I missed this in the fog, and you seem to have blown past some approvals and just done stuff.”
Nov 1. Three 120-character one-liners again. User: “command wrap syntax, lol, you just can’t learn that can you.”
Nov 1. User: “You are leaving me out of the loop”: Claude had started referring to everything by its own backlog numbers as if the user had them memorised.
The balance, measured
The cost of Claude’s own faults, audited by Claude on October 30th: 11 major incidents in 20 days, 10 of them Claude’s. Upper bound ~15 h of session time and 3.7 M output tokens; ~25 small ones of a few minutes each.
- Of 1,648 typed user messages, 86 carry a correction marker (5 %); Claude’s own stricter review on November 1st put the month at 8 %. Worst days: October 19th and 29th (11 %), 25th (9 %), 30th (8 %).
- Of 119 sessions with a typed user message, 75 had no correction at all; of the 85 sessions with four or more messages, 44 had none.
- 66 backlog items closed with their narrative kept; 948 commits, 83 % not a fix or revert.
- User messages with a praise or acceptance marker: 17.
Why it happens, and how the two work on it
- Claude quotes training memory instead of the device or the record: fingerprints, GUI pages, NIC counts.
- Claude reads one grep and states a fact; the baseline it wrote itself had the answer.
- Claude blames hardware before its own config.
- Claude re-derives things already decided and written down, whenever the boot read is skipped or token-starved. User: “don’t trust Claude, it’s leaving things out we already talked about and WROTE DOWN.”
- Claude ships tooling the user depends on (the launcher, the vault lock) without testing it from a second session.
- Claude buries the critical line in verbosity. User: “I like the verbosity, I just want critical things highlighted better.”
- The method that works: the user says it once, in capitals if needed; it becomes a standing rule; the rule goes where Claude actually loads it, not in a file it reads once; the transcripts get audited for whether it held.
- Rules that stuck: check, don’t guess. Decisions first. The user’s report is the first hypothesis, not the last. Commands under 75 characters. Arm the fallback before any test that can cut the link.
7. Pitfalls and what they cost
The user, in their own words: Even once you come off $200 for the month of use, with limits and quotas, you will get dinged for doing something called “Cyber”. This was a suprise to me, as I thought Cyber was a part of this whole thing. Yes, yes, I want to Cyber, I want to Cyber pretty hard bro, so hard it may scare your buddies at Anthropic. I also found out, you may think youre Cybering with Fable on some serious config stuff, but no, you are Opus 4.8 because you cyber to close to the sun. And, if the settings arent right, its not even gonna tell you.
Anthropic’s own stops, counted from the transcripts. Every stop has the same label: “This request triggered restrictions on violative cyber content and was blocked under Anthropic’s Usage Policy.” Through November 1st: 16 refusal messages in about 11 incidents (retries of the same blocked turn counted once), on October 12th (1), 14th (2), 16th (1), 23rd (1) and November 1st (6). Through November 4th: 26 messages. What was being done each time, from the session: setting up a Kali MCP server (the 14th); handling the DL160’s imaging drive (the 16th); a whole-file rewrite of the secrets broker (the 23rd; the lab’s rule since is small edits, one feature per commit); Wi-Fi driver troubleshooting on C6, firewall GUI steps, and a question about tool permissions on the Kali laptop (November 1st); after the window, TV certificate and DNS troubleshooting, a Wi-Fi test, and a recovery script. Not one was pentest work against anything but the lab’s own network. Two more mechanisms, both after the window: on November 2nd a flag silently switched the session to a smaller model in the middle of live firewall work (the setting that allows that is now off: a flag pauses and asks); and since auto mode on November 1st, the server-side classifier has refused 5 tool calls outright (one “dangerous” during Wi-Fi work, one secret-store write, two more “dangerous”, and one upload of this post’s preview to claude.ai, which was Claude’s mistake, not the classifier’s). The lab’s rule: a stop is never evaded; the work is restated within policy or handed to the user.
Quota as a wall. User, October 26th: “quota at 5 % for the week, work holds at the cap.” Verbose insight blocks switched off for “burning my quota”. Usage tracking built, then dropped as not worth its own cost.
8. Speed, idea to live (days from October 10th)
The user, in their own words: Are we cybering? Or are we playing Cyber pretend with our robot friend we bought?
- Firewall management lockdown: day 2.
- Secrets broker: day 11.
- Firewall migrated: day 15. AP on OpenWrt: day 15.
- VLANs: day 16.
- Local-model agent VM: day 20.
- Logging stack with dashboards: day 22.
- TV dashboard: day 23.
- What took a week when it shouldn’t have: Wi-Fi stability (open since day 17); copy/paste (4 days); the lockout and the launcher rework (3 days).
9. What’s next
The user, in their own words: We are gonna keep at it, keep tracking, keep seeing if we can improve. Ultimatley, the idea is to see if I can get a bunch of enterprise E waste out of storage boxes, on to a network, and serving some purpose. Can I get it all wired tight, can we make something cool for just under 2k of Bots and bits and bobs and then turn off the Flagship, turn off the recurring costs? Will we become addicted to the frontier models? Will the local models get so good you can run them on a 10 year old gaming tower with GTX cards? We will try to find out. I hope to learn, grow, develop, and have fun with all of you through this project. Please dont let my ram stacked E waste or my Gucci Frontier robot use discourage you and your project and the true spirit of Devember, which I am kinda cheating at.
