AI Disclosure:
I’ve used both Claude and Gemini to assist with configuration as well as Claude to vibe code control for my fans. All my sins will be confessed in the write-up.
Long time lurker and YouTube watcher, first time poster. I’ve been into computers for a long time, but I never have had a homelab. I was unfortunately laid off a bit ago and decided to go back to school for cybersecurity. I figured it was time to build one, so I had a proper platform to work on and get more familiar with the tools I was learning about. I’ve never been a programmer or sysadmin, but I worked with tech for 20+ years mostly from the user experience, product management, and project management perspectives.
I decided take inventory of years of gear I had around the apartment and found most of the components I need to build out a system.
Hardware:
- Corsair Obsidian 750D Case
- EverCool Dual 5.25 to Triple 3.5 HHD Bays
- Machinist X99-MR9D-PLUS**
- Xeon E5-2697v4
- Cooler Master Hyper 212 EVO
- 3 x 8GB DDR4-2133
- 1 x 8GB DDR4-2133 (that identifies as a 4GB stick)
- 1 x Timetec 128GB Sata SSD (boot drive)
- 2 x 1TB Samsung 840 EVO
- 3 x 2TB Random Hitachi HDDs (From old Lacie storage)
- 4 x 4TB HGST Deskstar NAS
- 2 x 8TB Seagate EXOS
- 1 x Generic Intel i226-v 2.5Gb NIC (Amazon Special)
- 1 x Generic Marvell 88SE9215 4-Port SATA Card (Amazon Special)
- 1 x RTX 2070 Super
- 1 x RTX 2080 Super
- 3 x Thermalright TL-C14C (replaced all the original case fans)
- 4 x Thermalright TL-C12C (replaced the original Cooler Master Fan and added 3 top of the case exhaust fans)
- 1 x Thermalright TL-8015 (replaced the fan that shipped with the Evercool)
- 1 x Arctic Fan Control (USB 2 header controlled)
- EVGA Supernova 1000 P2 PSU
Substitute MB:
- EVGA X99 Classified
Everything was recycled except for the Xeon (best $20 I’ve spent on eBay), the Machinist MB, the NIC, SATA card, the fans, and fan controller. Probably about $250 out of pocket including the random connectors and adapters I needed.
I decided to use HexOS (I had purchased a license when it was first announced on WAN Show) as I was looking for something with some depth, but I was willing to take short cuts if I could. The main goal was to get some local storage setup and start looking at self-hosted apps to begin removing my internet footprint.
Here’s the journey so far:
- Successful first boot and HexOS install with just the 4TB drives. I’m surprised everything worked. Installed Plex, did some validation, everything is looking good so I move my media from the 8TB drives which were in another system.
- Start running into all sorts of issues with the Machinist on-board NICs as they don’t have real MAC addresses. Ordered the 2.5G NIC.
- Tried to get the Arctic Fan controller to work as it has Linux “support”.
- First chased my tail for half a day as it plugged into the JLPC header because it looks like a USB 2 header but is not in fact a USB 2 header (despite the documentation saying there where 2 headers).
- After plugging it into right header, I have no joy trying to use it. It turns out the driver was added in kernel 7.2 where HexOS runs on TrueNAS Scale which is on kernel 6.18. After looking into what it would take to install a driver on TrueNAS Scale, I realized quickly it would be a bad idea to even attempt this.
- Turning to Claude before I returned it and just bought a fan hub, Claude suggested writing a python program that communicates directly with the device via /dev/hidraw. I need to preface this with level of knowledge with Linux is enough not to run sudo rm -rf / and the most complicated program I’ve written in python is a unit convertor, so I was well out of my depth here. After doing some basic testing, I had Claude code a python program that run in a docker container that allows me to set fan curves based on temperature for my drives and CPU. I plan to revisit this when I have some more time, but I get why vibe coding is attractive.
- After that lengthy side quest, I got the rest of my hardware installed and decided to replace the 28GB I had with 2 x 32GB DDR4 that was in another system. So, this is when I did a stupid and completely forgot that memory compatibility was a thing. The X99 platform does not support 32GB sticks. My guess on a mainstream motherboard it would error out, yell at me, but work fine when I put the original memory back. The Machinist really didn’t like it and got completely borked. With Aliexpress special, support is not really there so I turned to AI, Gemini in this case.
- With the assistance of Gemini, I used a CH341 programmer and a clip to first try to clear out the bad memory training in the bios. And when that wasn’t success, tried to load a “original” bios I found on github. No joy with that, so the Machinist board remains in a borked state.
- I did have my old EVGA Classified X99 board which seems to have bad C&D memory channels, but the other 4 slots work, so I loaded that up and did a motherboard swap and we are back in business.
- I’m still trying to get support via Aliexpress chat, but that running through the Ali AI for translation, and I’m not hopeful.
- After we were back up and running, I decided to try to get the machine running through a VPN via my Ubiquiti setup, but after a couple of hours of banging my head against a wall, I just couldn’t get it to work. I ended up find a better solution by running docker containers with Gluetun which was surprising easy and efficient to setup.
- I was about to start looking at reverse proxies, and then TrueNAS releases Anywhere which for $29/year felt like a better solution at this time. Of course it wasn’t without its own side quests.
- The domain I wanted to use was hosted at GoDaddy which seems to be an ad-farm that cosplays as a registrar. I ended up transferring to Cloudflare which let me to learning about certificates and getting ACME setup on TrueNAS.
- As a day one Anywhere subscriber there have been some issues and thing I’ve had to work through with my side, but the Eshtek guys have been cooking. If you are looking to install HexOS, join their discord, the support they provide is awesome.
- The big hurdle I’m working through is setting up my own IDP with authetik, which has been a challenge, but I think it will be worth it. I’ve been able to get BookOrbit and Sparkyfitness running and authenticating through it which is awesome. AI has been helpful in troubleshooting these config, but mostly because it will make some suggestions (none are my issues) but I’ll discover my issue while checking their suggestions.
Anyway, that was a wall of text, but it has been a great learning journey so far. I’ve learned a ton about docker and OICD authentication. I even learned how to program firmware (sort of). Some of my next steps are to revisit the vibe code and understand what’s going on with the fan control program. I also plan to start looking what I models I can load on to my video cards and start playing around with agentic AI, I haven’t explored that yet. It’s been a ton of fun, and I definitely plan to continue with this project for a long time.
