Does the ASRock DeskMini X300 support ECC memory? Has anyone tried? I have a Ryzen 7 PRO 4750G CPU which supposedly supports ECC, and 2x 32GB DDR4 ECC SODIMMs
ECC Support is needed by BOTH the CPU and the Mainboard… I’m [strongly] doubting it
idk if wendell has ecc so-dims but he could probably test it if he does
The reason I’m asking is ASRock generally has good ECC support on their motherboards. I haven’t found anyone actually trying it, though.
@wendell, I saw your video on the X300 and 4750G, and you mentioned potential ECC support. Have you had the time and/or opportunity to test ECC support?
It would’ve been more explicit - just seeing one listing of an ECC’d SODIMM model, would’ve been fighting chance, for additional supported models… Also the manual says non-ECC --> Unless it could become a perk, via a firmware upgrade?
