Designing cylinder shaped computer case
For Noctuas 200mm
Silverstone AP183 180mm fan
Spec pdf
This youtube video may help with design choices.
The internal frame is a great idea. Not sure how I feel about riveting everything.
Thanks for linking this, I remember seeing it a while back, I think the pipe would be a bit less fragile than what I could print at that thickness in PLA. The temperatures are a bit disappointing but the fans do look of modest performance.
OOOOOOOOOOOOO I love SFF builds
What are the heavy hitting power consumption parts like CPU and GPU
I recommend the hdplex 400
You’ll need either a external power brick like on laptops or they sell a internal ac to DC PSU
https://hdplex.com/hdplex-400w-hi-fi-dc-atx-power-supply-16v-24v-wide-range-voltage-input.html
https://hdplex.com/hdplex-nanoatx-power-supply-explained
