I'm a college student without much knowledge in computer programming and i was wondering if this community could help me... here's the story: School's wifi is horrid and doesn't allow my PS Vita to connect to it, so i purchased the asus RT-N56U. My first step was to password encrypt the connection so i wouldn't have to share it with any free loaders. About a month into the school year my internet connection dies suddenly, and kaspersky declares a a network attack DoS.Generic.SYNFlood has been blocked... 5000 of these... so with a power cycle of the router i was able to regain internet connection. In response i updated the firmware with a clean install, activated "ddos protection", and "reject ping requests WAN". 4 days later i get the same attack, same kaspersky reports, and same reaction. My third attempt was to hide the network's SSID... but that didn't disable the following attack 8 days later. This time i saved a txt file of the connections incoming and going from the router, in hopes of blocking a specific MAC address or an ip address that the attacker was using... they were changing with each attack... i'm at a loss here, is there any way for me to block this??? Thank you for reading.
I don't know how you could protect the router, but it might help thinking about the reason why you get attacked. Have you got any "enemies" or someone who likes trolling you?
get a vpn and white-list the vpn connection
also it might not be an attack, it could just bee a broken script somewhere. I can't see a reason to ddos a personal connection, when it would be so much easier to just break your operating system (assuming you are using windows)
my desktop which was getting attacked is using a wired connection, no wifi adapter connected to the desktop during the attacks. I'm a freshman at this college, so nobody really knows me, and the entire floor of my dorm got attacked one night, indiscriminantly of dorm room. A CENG major friend said that the attacks were being placed upon the router from it's wireless advertisement, rather then turn that off is there any way to prevent the next attacks either with a custom firmware for the router or a counter-attacking software that i could use that would be legal on campus?
DDWRT is good firmware but I would suggest getting a cheap PC and putting PFSense on it, do security that way, your router can only block so much.
Also SSID hiding and Mac filtering are no security improvement, they stop idiots but not people who can use aircrack, It can take a few mins to find one and then they can hijack an address and start all over again, I would suggest again wireshark.
Also pentest your own network, you can stop stuff like this, get a VPN with DOS protection, most have it.
Only other thing is IDPS but they are not cheap also configuring them can be a bit tricky, and if the hacker makes noise it will trigger the alarms.
IDPS is the best route though, do a wireshark and report back with your findings.
well if the previous posts should be disregarded... are there any other suggestions of how to prevent the TCP attacks?
