Any recommendation for a motherboard capable of handling 4x GPUs?
I would love to buy an older TR series (I don’t need THAT many cores), but I also would like compatibility with the TRX40 Socket since if I have to splurge on a motherboard I would like some measure of future-proofing.
Should I stick with the Corsair Case or are there better newer cases?
Honestly would go lowest of current gen TR so 3960x would be the move if you dont need cores, but you could get away with older stuff if the budget is tight, but I would shoot for current gen if you can afford it
Not a thing, so if you go old your locked into 2990wx being your top end chip
Honestly doesnt matter, pick what fits you and your hardware, more air flow is better obviously.
I think that since the budget should unlock during summer I will either hope for a decline in prices or simply go for a cheap old gen TR + mobo and splurge more on juicy GPUs since a TR 3960x (sooo sexy though) + mobo here in Italy sets you back more than 2K meaning almost a Titan RTX or 2x 2080ti. I don’t have that much single threaded workload anyway and can take the hit in the time being, renovating the GPUs takes the priority (but I might be waiting for the new batch of Green Team GPUs).
I should take a look at the release calendar for AMD and NVIDIA and time the purchase accordingly.
