Just wondering if anybody knows of any decent speakers that are fairly thin. The space I'd like to put them in is about 60mm by 180mm (2 3/8in by 7in). I'm not looking for anything that will blow my socks off and melt my ear drums, but I would like them to be half decent sounding for classical and/or some lighter hip hop.
not saying they don't exist, but the problem you will run into is every speaker save for cheap headphones has been tuned to a frequency. That is achieved by the box the speaker is in. You could always build your own box with no tuning, but that can cause problems. another option is a sound bar on the wall. but most regular pc speakers are more than 2" deep. could you please provide EXACT detail on height x depth x width in that order to more clearly help?
I looked at the space again and I could go with two speakers/boxes that are 60mm x 180 mm x 100 mm (H x W x D)
OR
Two that are 100 mm x 300 mm x 200 mm (H x W x D) if they can support the weight of one monitor each.
Both options are roughly +/- 5 mm on each dimension.
I'm trying to figure out if I can get something to fit between my desk and the bottom of my screen or something that I can put a monitor, stand and all, on top of.
http://www.noiseaddicts.com/2009/04/thinnest-speakers-in-the-world-flat-flexible/
246.38 x 187.96 x 284.48 If you lay this on its side, you may be able to put the monitor on top
http://www.guitarcenter.com/item/default.aspx?itemno=3225366 you can also buy stands for either side of your desk, saving space
http://www.guitarcenter.com/On-Stage-Stands-Speaker-Wall-Mount-Bracket-Pair-104508429-i1410650.gc
http://www.guitarcenter.com/American-Recorder-Technologies-Studio-Monitor-Speaker-Stand-Pair-102527769-i1142319.gc
self standing stands
If only those were about half as wide :(
So, anybody have any experience with the Creative Gigaworks T40? They look like they should fit under the edges of my screen decently.
http://www.newegg.com/Product/Product.aspx?Item=N82E16836116044
They will work better than regular Altec Lansings. That is about it. You wont get any smaller unless you get a mini sound bar or decide to screw 2' speakers to a piece or plexi.
