DeathAdder 2013 Vs. Corsair M65 Mice
Which one should I get, I will note that I have longer than average fingers, and they are a bit thin, I am just a thin person. So which one would be best for me, I will also say that I know for sure the M65 beats the Death adder in Specs but I am also concerned with comfort.
Help?
It is really a personal decision. The best thing to do is try them both out. You can return it if you don't like the one you got.
I have a razer deathadder 2012 and it works for me, I personally hold my mouse in a "claw fasion" which means I do not rest my palm on the mouse.
I haven't used a death adder personally but i hear they are a good value. But i do own a M65 and I LOVE IT
logan reviewed it  >> here <<   I made my own sort of review in the comments of that thread if you want to read some of it. any questions about the M65 i can answer.
They both sound great, decisions, decisions... Anyway thanks for the feed back guys!
I would go with an m40 over the m65 because its got the 3090 sensor instead of a lazer sensor otherwise the deathadder is a great option too the black edition and the 2013 are the best I think and the main difference in the 2013 is very light the black edition is a little heavier and the m40 has adjustable weights.
I own an M95 (different, I know) and I love it also.
Deathadder if your into fps, it's one of the bests sensors. When set to 0 acceleration it really has no acceleration which many mice can not claim. It also has a very small LOD which is pretty important for low sens fps. I can't  speak about the corsair mouse, tho none of them seemed overly appealing to me when looking for mice.
They're both great but you would have to experience each mouse in order to make the best decision. I have a M65 and I love it. I tried my friends Deathadder and it felt great in my hand, but sort of wierd as it is much wider than the M65 to me. Really its mostly up to the way you feel holding the mouse.
