Death of PS3 first gen
Hi
My 5 year old ps3 has just died this morning. It was death through the yellow light of doom.
My first though was " Die Bi..." but then I wanted to play through the last of us again....
So I took it apart and did the heat fix thing. It worked for 10min and now its dead again.
Should I try the fix again of is there is something else I can do!!
Long live the PC!
Thx
buy new ps3. put old ps3 in new ps3's box. return to bestbuy.
Remember when the old consoles could take a beating and keep going. However I have never had a console die on me, Once I got a RROD on the crapbox360 fixed it and its been good ever since. I can tell you where there is a will there is a way. I do know this worked for a friend of mine with his PS3.
http://www.youtube.com/watch?v=50Qri-971so&noredirect=1
Yeah I found a place that fixes to motherboards cheap. They resolder the "whole" thing. Ill give it a go this monday. If not Ill just get a new motherboard from them. I really need to play the last of us again.
Be sure you get a replacement 1st gen, whatever you do. Its the only gen that can natively play any PS2/PS1 game.
seriously, i bet my nintendo in the garage still works ,just need to give a good blast of air.
i'd be interested as i need a usb3 on-board port re-solder.
It was the 60gb version that had the ps1/2 game support I think. The one I have is the 40gb the veeery first one I believe. Ill let you know how it works out.
Every 1st gen PS3 should have the ability to install CW easily. I want to get mine repaired.
Haha, my PsOne still works. Newer consoles are dropping like flies while the older ones never stop working.
Yeah, without backwards compatibility it's barely worth having.
Commiserations. To be honest I am a computer guy. Growing up in the 80s and 90s in the UK you just were. However the Dreamcast and PS3 have been faithful consoles to me. Like Logan I love PC, but I also love games.
So I hope you get it Fixed. I assume you have PS2 compatibility?
