Hello, I hope you are having a fantastic day. I’m presently learning about Database Management Systems (DBMS) and Relational Database Management Systems (RDBMS), however I’ve run into a few challenges while dealing with SQL. I’m reaching out to ask for your help in conquering these obstacles.
Here’s a bit of the SQL code I’ve been working with:
-- Creating a table in an RDBMS
CREATE TABLE Employee
EmployeeID INT PRIMARY KEY,
FirstName VARCHAR(50),
LastName VARCHAR(50),
Department VARCHAR(50);
In this SQL code sample, I’ve noticed four difficulties that I’m attempting to solve:
1.The CREATE TABLE statement appears to have a syntax issue. Can you help me find and rectify the syntax mistake that prevented me from correctly creating the “Employee” table?
2.While attempting to specify the primary key for the “Employee” table, I received an error message stating “missing ‘(’ after ‘PRIMARY’”. How can I fix this problem and correctly declare the main key?
3.The data types for the columns “FirstName,” “LastName,” and “Department” are defined, but I’m not sure whether they’re suitable. Could you please advise on picking acceptable data types for these columns?
4.I added semicolons at the end of each line, but I’m not sure if this is essential or if it would cause problems. As shown in that source, Should semicolons be used in this situation, and if not, what is the proper approach?
Your comments and knowledge would be highly welcomed as I face these problems. Thank you for your help.
