I’ve been running my unRAID server with a PCI Passthrough gaming VM for about 7 or 8 years now, this particular system for about 6 and had little to no trouble with it.
I recently upgraded my system to a 5900X and a RX 6750 XT (I can post full specs of the server if needed) and decided to try out Cyberpunk 2077. My old system could run the game, but not particularly well, and I got less than stellar framerates. The old system was a Ryzen 1700 and GTX 1080.
Now, when I run the Cyberpunk benchmark, I get right around 20 FPS regardless of settings. Low to Ultra, it all runs the same. But in baremetal windows, I can get 90+ FPS on Ultra settings. What gives? In the VM, I look at task manager and the GPU usage is only like 15-20%, and CPU is only around 40% so its not bottlenecking I don’t think…Something is different between the baremetal system and the VM.
Any ideas where to look? I’ll include the XML for my unRAID gaming VM below to look at. Again, other games all run just great, this is so far the only one I’ve run into that runs bad.
Let me know what else might be useful and I’ll be happy to provide the info!
<?xml version='1.0' encoding='UTF-8'?>
<domain type='kvm' id='5'>
<name>Windows 10</name>
<uuid>afb22e68-6160-c234-7de8-a72f6d0501f6</uuid>
<metadata>
<vmtemplate xmlns="unraid" name="Windows 10" icon="windows.png" os="windows10"/>
</metadata>
<memory unit='KiB'>25165824</memory>
<currentMemory unit='KiB'>25165824</currentMemory>
<memoryBacking>
<nosharepages/>
</memoryBacking>
<vcpu placement='static'>12</vcpu>
<cputune>
<vcpupin vcpu='0' cpuset='6'/>
<vcpupin vcpu='1' cpuset='18'/>
<vcpupin vcpu='2' cpuset='7'/>
<vcpupin vcpu='3' cpuset='19'/>
<vcpupin vcpu='4' cpuset='8'/>
<vcpupin vcpu='5' cpuset='20'/>
<vcpupin vcpu='6' cpuset='9'/>
<vcpupin vcpu='7' cpuset='21'/>
<vcpupin vcpu='8' cpuset='10'/>
<vcpupin vcpu='9' cpuset='22'/>
<vcpupin vcpu='10' cpuset='11'/>
<vcpupin vcpu='11' cpuset='23'/>
</cputune>
<resource>
<partition>/machine</partition>
</resource>
<os>
<type arch='x86_64' machine='pc-i440fx-6.2'>hvm</type>
<loader readonly='yes' type='pflash'>/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi-tpm.fd</loader>
<nvram>/etc/libvirt/qemu/nvram/afb22e68-6160-c234-7de8-a72f6d0501f6_VARS-pure-efi-tpm.fd</nvram>
</os>
<features>
<acpi/>
<apic/>
<hyperv mode='custom'>
<relaxed state='on'/>
<vapic state='on'/>
<spinlocks state='on' retries='8191'/>
<vendor_id state='on' value='none'/>
</hyperv>
</features>
<cpu mode='host-passthrough' check='none' migratable='on'>
<topology sockets='1' dies='1' cores='6' threads='2'/>
<cache mode='passthrough'/>
<feature policy='require' name='topoext'/>
</cpu>
<clock offset='localtime'>
<timer name='hypervclock' present='yes'/>
<timer name='hpet' present='no'/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>restart</on_crash>
<devices>
<emulator>/usr/local/sbin/qemu</emulator>
<disk type='block' device='disk'>
<driver name='qemu' type='raw' cache='writeback'/>
<source dev='/dev/disk/by-id/ata-WD_Blue_SA510_2.5_1000GB_223326801852' index='1'/>
<backingStore/>
<target dev='hdc' bus='sata'/>
<serial>vdisk1</serial>
<boot order='1'/>
<alias name='sata0-0-2'/>
<address type='drive' controller='0' bus='0' target='0' unit='2'/>
</disk>
<controller type='virtio-serial' index='0'>
<alias name='virtio-serial0'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x05' function='0x0'/>
</controller>
<controller type='sata' index='0'>
<alias name='sata0'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x04' function='0x0'/>
</controller>
<controller type='pci' index='0' model='pci-root'>
<alias name='pci.0'/>
</controller>
<controller type='usb' index='0' model='qemu-xhci' ports='15'>
<alias name='usb'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0'/>
</controller>
<interface type='bridge'>
<mac address='52:54:00:76:00:5c'/>
<source bridge='br0.20'/>
<target dev='vnet4'/>
<model type='virtio-net'/>
<alias name='net0'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x02' function='0x0'/>
</interface>
<serial type='pty'>
<source path='/dev/pts/4'/>
<target type='isa-serial' port='0'>
<model name='isa-serial'/>
</target>
<alias name='serial0'/>
</serial>
<console type='pty' tty='/dev/pts/4'>
<target type='serial' port='0'/>
</console>
<channel type='unix'>
<source mode='bind' path='/var/lib/libvirt/qemu/channel/target/domain-5-Windows 10/org.qemu.guest_agent.0'/>
<target type='virtio' name='org.qemu.guest_agent.0' state='connected'/>
<alias name='channel0'/>
<address type='virtio-serial' controller='0' bus='0' port='1'/>
</channel>
<input type='tablet' bus='usb'>
<alias name='input0'/>
<address type='usb' bus='0' port='4'/>
</input>
<input type='mouse' bus='ps2'>
<alias name='input1'/>
</input>
<input type='keyboard' bus='ps2'>
<alias name='input2'/>
</input>
<tpm model='tpm-tis'>
<backend type='emulator' version='2.0' persistent_state='yes'/>
<alias name='tpm0'/>
</tpm>
<audio id='1' type='none'/>
<hostdev mode='subsystem' type='pci' managed='yes'>
<driver name='vfio'/>
<source>
<address domain='0x0000' bus='0x0c' slot='0x00' function='0x0'/>
</source>
<alias name='hostdev0'/>
<rom file='/mnt/user/isos/BIOS Dumps/6750XT.rom'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x03' function='0x0'/>
</hostdev>
<source>
<address domain='0x0000' bus='0x0c' slot='0x00' function='0x1'/>
</source>
<alias name='hostdev1'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x06' function='0x0'/>
</hostdev>
<source>
<address domain='0x0000' bus='0x07' slot='0x00' function='0x0'/>
</source>
<alias name='hostdev2'/>
<address type='pci' domain='0x0000' bus='0x00' slot='0x08' function='0x0'/>
</hostdev>
<hostdev mode='subsystem' type='usb' managed='no'>
<source startupPolicy='optional'>
<vendor id='0x046d'/>
<product id='0xc07c'/>
<address bus='1' device='2'/>
</source>
<alias name='hostdev3'/>
<address type='usb' bus='0' port='1'/>
</hostdev>
<vendor id='0x0c45'/>
<product id='0x7605'/>
<address bus='7' device='3'/>
</source>
<alias name='hostdev4'/>
<address type='usb' bus='0' port='2'/>
</hostdev>
<source startupPolicy='optional' missing='yes'>
<vendor id='0x047f'/>
<product id='0xc05e'/>
</source>
<alias name='hostdev5'/>
<address type='usb' bus='0' port='3'/>
</hostdev>
<memballoon model='none'/>
</devices>
<seclabel type='dynamic' model='dac' relabel='yes'>
<label>+0:+100</label>
<imagelabel>+0:+100</imagelabel>
</seclabel>
</domain>
Thanks in advance!
