Any suggestions would be super great... Just thought of doing a build like this but I'm not sure if it would all fit and if that included power supply would work? I did try out a power supply calculator and it said id only need 430 watts but I'd just like to be sure; That and I kind of doubt that graphics card will even fit... Any help is greatly appreciated! Thanks!
Edit: Also... Should I worry about getting an aftermarket cooler? And if so, would one even fit?
Any info on the included power supply? Also not sure on graphics card clearance, but I am sure you can get the info for that on the google machine. I would also save a little for a SSD later on, best upgrade you can do IMO.
Well.. my issue would the be price.. the one I chose is only $260 which is honestly cheap as hell in my opinion for that card.. but if they're comparable then sweet.
