could i fit the
Lian Li O11D-1X Vertical GPU Bracket KIT PCI-E 3.0 for O11 Dynamic Only
in to my Thermaltake CTE T500 TG
id like to have the air blow across my xfx 6750xt triple fan an my
Sonnet McFiver PCIe Card mounted with two WARP Shield H NVMe heatsinks instead of at them
iv got two cte 500 cases with near the same config both have the same gpu an McFiver card
an in each a ARCTIC Liquid Freezer III 280 (in pull config with 2x 140mm vrm cooling ducts aimed at the glass)
is rear mounted with the top rear vertical 140mm free as intake an the top 140mm to with
my front 3 x 140mm an the bottom 140m are all rigged as exhaust , this has been the best layout for my temps
minus the build up on the m2 card during heavy load which the solution was to mount sideways i did this done jury-rigged for a
short term test with steel bailing way (not safe or pretty) but caused the temps on both the gpu an m2 card to drop by 10c (gpu)
13c on the m2 this was exactly what i needed so if the Lian-Li adapter could be fitted that would be great.
