This is a 32" 2560x1440 display. It uses a relatively new process generation of A-MVA+ -- and rivals or beats IPS in terms of RGB color space. (You will need your own color calibrator if that's important to you, though).
Item Description - 32" (81 cm) - 2560 X 1440 @ 60Hz (WQHD) - Real 75Hz - Cross Hair - Speed 5ms - Low Blue Light - Color 1.07M - A-MVA+ - Remote(Button language : English) - Smart Stand - DCR 5,000,000:1 - Flicker-Free - Eco Backlight
Specifications Brand : Crossover Model :32SS QHD DP Freedom Panel : A-MVA+ Screen size : 708.4 mm (H) x 398.5 mm (V) Aspect Ratio : 16:9 Resolution : 2560 X 1440 @ 60Hz WQHD Response time : 5ms (GTG) View Angle :178 (H), 178 (V) Brightness : 300cd/㎡ Contrast Raito : 3000:1 Pixel Size : 276.65 x 276.65 (per one triad) Display Color : 1.07b Colors Optimal resolution : Displayport 2560x1440 @ 60Hz, HDMI 2560x1440 @ 60Hz, DVI 2560x1440 @ 60Hz, RGB 1920x1080 @ 60Hz
Port : Displayport, HDMI, DVI, RGB, Audio IN OUT, DC Speakers : 10W X 10W VESA mount : 100mm x 100mm Power Adapter : AC 100V~240V (Free Voltage), 50~60Hz Size(With stand) : 733(W) x 490(H) x 200(D) mm Weight(With stand) : 7.7 Kg
Plug Type : Korean C Type Plugs *Including remote control (Button Language : English)
I want to buy a new freesync screen this year Im looking at AUD$250-AUD$350 for a new screen
Ive seen good things mentioned on the old QX2710-LED-Evolution-ll which has been around for years
Does this 32" support 1440p 75hz or 95hz on freesync ? Also how do we lock games at 75hz or 90-95hz
Currently using a crapo 24" TV LCD via VGA since my 500 buck asus 27" LCD died and they refused to fix it under warranty 2 weeks before the warranty perioid ran out ...
Otherewise if you manage to find an 25" IPS 1440p 75-95-144hz screen i would be interested aswell
Has anyone come across 24-25" 75hz 1080p really tiny bazel freesync screens ? Either korean or normal american brands ?
I would love to have three screens together really close for wide 3 screen gaming if they actually sold 3 as a kit or 3 screens with ultra tiny small bazels (eg ETS/Dirt Rally/Project Cars/Star Citizen/etc)
Annoyingly LG sell the 23MP68VQ which is just what you want, but only in Europe. Though Amazon.co.uk might ship to you. I have done the reverse before, evening using my own account. Power suggests it might just take 110v http://www.lg.com/uk/monitors/lg-23MP68VQ-P
Just checked, one store (scroptec) lists it for AUD$249 which makes the 23' 1080p 75hz pointless when you can get the 24" 1080p 75hz screns for AUD$170
I went ahead and ordered one of these from Amazon! Though I'd prefer 4K at ~40", the size and price were right for what I need at the moment.
Unfortunately, it's sitting in a warehouse a few miles away... Fedex says they need a radiation form in order to finishing shipping it. Has this happened to anyone here before?
