Crossflashing Intel official firmware on Ericsson XXV710-DA2 nics
Does anyone have any advice on how to go about trying to crossflash Ericsson Intel nics as I am not entirely sure as to what config/firmware file I am supposed to use for it. <3
0004:01:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller XXV710 for 25GbE SFP28 [8086:158b] (rev 02)
        Subsystem: TELEFON AKTIEBOLAGET LM Ericsson Device [1519:0002]
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0
        Interrupt: pin A routed to IRQ 371
        IOMMU group: 9
        Region 0: Memory at a400000000 (64-bit, prefetchable) [size=16M]
        Region 3: Memory at a402800000 (64-bit, prefetchable) [size=32K]
        Expansion ROM at a040000000 [disabled] [size=512K]
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
                Address: 0000000000000000  Data: 0000
                Masking: 00000000  Pending: 00000000
        Capabilities: [70] MSI-X: Enable+ Count=129 Masked-
                Vector table: BAR=3 offset=00000000
                PBA: BAR=3 offset=00001000
        Capabilities: [a0] Express (v2) Endpoint, IntMsgNum 0
                DevCap: MaxPayload 2048 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0W TEE-IO-
                DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
                        RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop- FLReset-
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
                LnkCap: Port #0, Speed 8GT/s, Width x8, ASPM L1, Exit Latency L1 <16us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkCtl: ASPM Disabled; RCB 64 bytes, LnkDisable- CommClk-
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt- FltModeDis-
                LnkSta: Speed 8GT/s, Width x8
                        TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR-
                         10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
                         EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
                         FRS- TPHComp- ExtTPHComp-
                         AtomicOpsCap: 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-
                         AtomicOpsCtl: ReqEn-
                         IDOReq- IDOCompl- LTR- EmergencyPowerReductionReq-
                         10BitTagReq- OBFF Disabled, EETLPPrefixBlk-
                LnkCap2: Supported Link Speeds: 2.5-8GT/s, Crosslink- Retimer- 2Retimers- DRS-
                LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+ EqualizationPhase1+
                         EqualizationPhase2+ EqualizationPhase3+ LinkEqualizationRequest-
                         Retimer- 2Retimers- CrosslinkRes: unsupported, FltMode-
        Capabilities: [100 v2] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP-
                        ECRC- UnsupReq- ACSViol- UncorrIntErr- BlockedTLP- AtomicOpBlocked- TLPBlockedErr-
                        PoisonTLPBlocked- DMWrReqBlocked- IDECheck- MisIDETLP- PCRC_CHECK- TLPXlatBlocked-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt+ UnxCmplt- RxOF- MalfTLP-
                UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+ CorrIntErr- HeaderOF-
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+ CorrIntErr- HeaderOF-
                AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
                        MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
                HeaderLog: 00000000 00000000 00000000 00000000
        Capabilities: [140 v1] Device Serial Number 08-49-df-ff-ff-fe-fd-3c
        Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
                ARICap: MFVC- ACS-, Next Function: 1
                ARICtl: MFVC- ACS-, Function Group: 0
        Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
                IOVCap: Migration- 10BitTagReq- IntMsgNum 0
                IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy- 10BitTagReq-
                IOVSta: Migration-
                Initial VFs: 64, Total VFs: 64, Number of VFs: 0, Function Dependency Link: 00
                VF offset: 272, stride: 1, Device ID: 154c
                Supported Page Size: 00000553, System Page Size: 00000001
                Region 0: Memory at 000000a402000000 (64-bit, prefetchable)
                Region 3: Memory at 000000a402810000 (64-bit, prefetchable)
                VF Migration: offset: 00000000, BIR: 0
        Capabilities: [1a0 v1] Transaction Processing Hints
                Device specific mode supported
                No steering table available
        Capabilities: [1b0 v1] Access Control Services
                ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
                ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
        Capabilities: [1d0 v1] Secondary PCI Express
                LnkCtl3: LnkEquIntrruptEn- PerformEqu-
                LaneErrStat: LaneErr at lane: 0 1 2 3
        Kernel driver in use: i40e
        Kernel modules: i40e
[04:001:00:00]: Intel(R) Ethernet Controller XXV710 for 25GbE SFP28
        Vendor                 : 8086
        Device                 : 158B
        Subvendor              : 1519
        Subdevice              : 0002
        Revision               : 2
        LAN MAC                : 3CFDFEDF4908
        Alt MAC                : 000000000000
        SAN MAC                : 3CFDFEDF490A
        ETrackId               : 8000D769
        SerialNumber           : 0849DFFFFFFEFD3C
        NVM Version            : 9.16(9.10)
        PBA                    : K53323-000
        VPD status             : Valid
        VPD size               : 25
        NVM update             : No config file entry
          checksum             : Valid
        OROM update            : No config file entry
          CIVD                 : 1.3179.0
          PXE                  : 1.1.42, checksum Valid
          EFI                  : 4.9.13, checksum None
What problem are you trying to solve? Why would you even want to cross-flash firmware in the first place?
These are instructions for the Intel X710 10Gbit card, the steps are probably the same. You will need to use a different firmware image since you have a different card but it should still be in the same Intel firmware and tools bundle
The issue is I am struggling to figure out which firmware would actually work on my card.
bump
hi,
Were you able to flash your card. I may have to do the same for Dell card.
Hi Everyone,
I was able to flash xxv710-da2 with intel firmware (Using EFI shell downloaded from Debian website).
PBA J46998
Complete driver pack from Intel website : Release_31.2.2.zip
Firmware used : XXV710DA2_9p57_CFGID12p0_OEMGEN.bin
I’d be careful with crossflashing this one. The Ericsson subsystem ID and NVM 9.16 suggest you’ll need the exact XXV710 NVM package for the target card, not just a generic config file. I’d dump and back up the current NVM first before trying anything.
