Warning
This procedure is risky and will delete all data! Always back up data and double check device paths before flashing.
There’s always a chance cross-flashing could brick the drive. I’m not taking any responsibilities here!
You have been warned!
Background
I use Dell-branded Kioxia PM5 drives (model KPM5XRUG3T84) in my NAS setup for a very specific reason:
Dell actually publically publishes firmware updates.
So when I stumbled over a very cheap pair of brand new Dell PM5s on eBay, I had to get, thinking they’d be just like my existing ones. Big mistake! Turns out they wer Dell EMC branded (still same serial) which aren’t quite the same:
- They showed up under a different name: P5R3T84A EMC3840
- They had a different firmware (PA5G)
- Dell’s standard update tools didn’t recognize them for firmware updates
- The EMC firmware isn’t available publicly (it’s locked behind Dell EMC entitlement system)
I want to run the latest firmware however. So I was just about to ask for advice here when on a whim I asked ChatGPT first, not expecting anything. It gave me some great pointers however. With a little trial and error I managed to cross-flash Dell’s standard firmware (B02A):
Here’s how I did it.
Install necessary tools:
sudo apt install sg3-utils lsscsi -
Identify the SAS device:
lsscsi -g
Look for your PM5 drives and note the corresponding /dev/sgX path. -
Extract the firmware:
Download Dell’s firmware update package for the Kioxia PM5 (e.g. from Dell Support). The raw firmware blob can be extracted from the RHEL installer with the --extract option (Works on other distros, too). It can also be taken from the “Dell PowerVault ME Series Storage HDD/SSD Firmware” package.
In my case, it was called: B02A.bin -
Flash the firmware:
sudo sg_write_buffer -vvvvv -m 5 --in B02A.bin /dev/sgX
Replace /dev/sgX with the device path from step 2.
The -m 5 mode is for “Download Microcode and Save” — this writes and persists the firmware. -
Reboot and verify:
I used “hdsentinel” to confirm the firmware version has been updated. The drives will now show up as “TOSHIBA KPM5XRUG3T84”.
