I want to start getting into Cronjobing things.
Does anyone have a good link to a list of useful common Cronjobs. I see alot of tuts on the tube to set one up.
Hereās my systemd setup for random background changes on Gnome 3. May it inspire you!
Note: this isnāt a cron job. Itās a systemd timer. Same kind of thing though.
Note on the following: Look at the list
variable. I use a two folder deep hierarchy on my Wallpapers directory. Youāll have to modify it for whatever you use.
$ cat ~/.local/bin/randbg
#!/bin/bash
list=(~/Pictures/Wallpapers/*/*)
index=$((RANDOM % ${#list[@]}))
image="${list[$index]}"
verbose=0
x="$1"
while shift; do
case "$x" in
-v) verbose=1;;
esac
x="$1"
done
gsettings set org.gnome.desktop.background picture-options zoom
gsettings set org.gnome.desktop.background picture-uri "$image"
gsettings set org.gnome.desktop.screensaver picture-options zoom
gsettings set org.gnome.desktop.screensaver picture-uri "$image"
[ $verbose = 1 ] && echo -e "$image\t$index/${#list[@]}"
exit 0
Note: Looks like I had to use a full path to the program here which includes my home directory. Remember to replace it with your own.
$ cat ~/.config/systemd/user/randbg.service
[Unit]
Description=change background randomly
[Service]
ExecStart=/home/zlynx/.local/bin/randbg
Type=oneshot
$ cat ~/.config/systemd/user/randbg.timer
[Timer]
OnBootSec=1
OnUnitActiveSec=5m
[Install]
WantedBy=timers.target
And donāt forget:
$ chmod +x ~/.local/bin/randbg
$ systemctl --user enable --now randbg.timer
I donāt have any profound uses for cron, just running a command I already would run, automatically at the set time. Things like backup scripts, btrfs scrub/defrag/balance, etc.
This site is awesome for making sure you have the expression setup correctly so it will run when you want it too.
https://crontab.guru/
Also, if you are emailing the output, which is important if you are using cron for things like backups, I would suggest using cronic. It makes commands quiet, unless it exits with a non-zero, or outputs stderr, which makes cron not email you unless something has gone wrong, which is better then emailing you every single time, or never emailing you.
Thanks @zlynx!!! I will start tinkering in my VM.
Iām Gnome-ubuntu 18.04
Ya rammed that in with no success
none of the config and systemd folders, and files were there. So i created them all in my user homefolder and nothing happened.
Does that randbg script run on its own and change the background? You need some wallpaper images in the directory you use to build the list
variable.
Open and terminal and run randbg
and fix it until it works.
i run randbg in terminal and nothing happens. The photos are in the folder. Tried fixing it.
In the randbg.timer & randbg.service where you have /user/ is it actually user or your user account name?
So thereās some script debugging tricks. You can run bash -x ~/.local/bin/randbg
and it will output every command it is running.
You can also put an echo
in there wherever. Like, if you want to see what it is getting for the list
array you can do this:
echo list=${list[@]}
And for debugging you want to keep for later you can use that verbose
variable, like I did for a couple of things.
That ~/.config/systemd/user/
is actually /user/
. Itās a systemd directory where you put user units, as opposed to system units. The ~/.config
directory is like /etc
but for individual users.
So global systemd units are in /usr/lib/systemd/system/
if theyāre from packages, or /etc/systemd/system
if theyāre local sysadmin configuration. There are default, system-wide user units too, in /usr/lib/systemd/user
all i keep getting is:
bash: ~.local/bin/randbg: No such file or directory
Whoops, I missed a slash somehow. You need to make that ~/.local/bin/randbg
. Sorry.
Well sorry, I canāt debug that from here. Did you put the randbg file in there, or not?
Okay. Thanks iāll keep looking at it
So I revised this fiddled with it got output of:
aarasdvadsv@dsagdfbsdf:~$ bash -x ~/.local/bin/randbg echo
list=(~/home/aarasdvadsv/Documents/Wallpapers/)
index=0
image=/home/aarasdvadsv/home/aarasdvadsv/Documents/Wallpapers/
verbose=0
x=echo
shift
case ā$xā in
x=
shift
gsettings set org.gnome.desktop.background picture-uri /home/aarasdvadsv/home/aarasdvadsv/Documents/Wallpapers/
gsettings set org.gnome.desktop.screensaver picture-uri /home/aarasdvadsv/home/aaarasdvadsv/Documents/Wallpapers/
ā[ā 0 = 1 ā]ā
exit 0
fixed it the last one, now this,
alpha#sprite@matrix:~$ systemctl --user enable --now randbg.timer
Failed to enable unit: Unit file /home/alpha#sprite/.config/systemd/user/timers.target.wants
/randbg.timer does not exist.
So itās looking in the timer.target.wants
folder but i donāt know why itās going to that folder location? I got it going on 18.04 but 20.04 doesnāt like it.
It looks like you donāt have the randbg.timer file in .config/systemd/user/
The window resizing glitched the whole gnome dash (VM) but i changed the gseting from zoom to stretch and itsā working seemless now.
But tried do it on the desktop and it didnāt work.
