The goal is to give the user a point if he presses the button while the LED is on, if the user presses the button while the LED is off they loose a point. Any ways you would do this or make it better? I am a beginner in Arduino and code I always feel like my code could be better/more effecient.
Have you tested it? From a brief look it appears to be all good. My only recommendation is that unless you plan to have points beyond 2147483648 or less than -2147483648, you should use some "short"s, same goes for that pointState variable. That said I don't have an Arduino myself, but I head and teach programming for my Schools FIRST robotics team.
It works mostly how I want it, the main thing I don't like is, though it that it doesn't add a point right away, it has to wait for the next Metro Interval to add it.
So if I press the button the first time the LED flashed, it doesn't get added and printed until the second time it flashes.
The only values that should be assigned to a boolean variable are true or false. If you want to use other value, boolean is not the right type.
Code:
Metro ledButton = Metro(0);
Some explanation of what the argument to the Metro constructor would be useful.
Code:
int button = 2; int led = 13; int points = 0; int pointState = 3;
In the same way that state variables should have state in the name, so should pin number variables. That helps tremendously when you go to read a pin and save it's state. Which variable goes where is self-documenting.
Code:
if (pointState == HIGH){ points++; pointState = 3;
WTF? Mixing LOW and HIGH and 3 in assigning a value to a variable with state (it should be either HIGH or LOW) makes no sense.
Code:
Serial.println(points);
If you worked for me, you'd get the rest of the day off. Without pay. NEVER print a value without some explanatory text. That makes debugging way harder than it needs to be.
To me it seems to be because you are calling Serial.println(); only after the "else" case when checking button presses. Remove the call from the nested if/else block and it should print your points every loop. That is what you want as I understand it? If I could find my Arduino I'd test it for you but from eye-balling it everything looks ok :-)
Well I do agree with him when it comes to naming conventions for writing Arduino code. It helps a bunch when you have to come back to it after a month and try to figure out what the code is supposed to do. I'd personally do pin_led = 13; var_points = 0; etc just so that I know what each variable is for and how it's supposed to work. But as for the rest of his post, he's just being a dick. :-/
He replied again clarifying some things, I agree that I should use 0, 1, and 2 for the pointStates instead of LOW, HIGH, and 2. It just makes it easier to read in now that I step back and look at it. And as for "I shouldn't assign LOW or HIGH to a boolean I'm not sure about, considering they both equat to the same thing.
While they are both the same thing when compiled the convention with a boolean variable is true or false. Think of boolean as the answer to a statement. A statement is either true or false such as an if statement. High and low are used to describe the state of an input or output. I cannot recall using high and low outside of IO pins for the arduino for purposes of clarity.
His ending statement is pretty harsh as I would imagine you do not have professional formal training otherwise you would not be asking this question in the first place.
