Yes, I do realize that by asking if it's good enough is subjective thus not clear enough.
Without further ado, I present to you, my build: pcpartpicker.com/p/Nvik
Let me start off by saying that I'll be using it for Hi-End gaming playing on a 1920x1080 monitor and the bugdet is set at 1400$. I'm also using Adobe Programs (Like Photoshop and After Effects). Even though nVidia's cards have CUDA cores which are better for rendering, I won't be doing dynamic visual editing to an extend that the Radeon I've chosen will not be able to handle (so I believe.) Make any suggestions and recommendations freely.
Thanks.
Good set up but go with ram sticks that are lower profile or thay may not fit with the aftermarket heatsink/cooler
it looks pretty nice so far. i would go with
http://pcpartpicker.com/part/corsair-cpu-cooler-h110
because its an 8 core and you're going to be doing alot of HI-end stuff. so it seems that it would be a good choice for all the stuff going on.
another thing is that i would stock up for cooling because agian its a very important system and it needs to cool correctly im assuming.
cheers dude.
and good luck.
http://pcpartpicker.com/p/OtoM
Better in like, every single way.
Well yeah, I'm not sure about overclocking issues, I'm in a dilemma on if I should overclock or not. You see, choosing the 212 EVO won't allow me to overclock, correct? Now the real question is if I should or not... any suggestions?
LOL you can go for 7950 CF system with that cash...
On what resolution are you playing?
http://goo.gl/XGYCt
http://pcpartpicker.com/p/OtBQ
Oh Lord...
Its not that I care what and where will you buy, but would you explain to me how does your mind works?
Uh, I'm sorry? I believe that this ram fits with the cooler, right?
it shude do (there a lot smaller than the corsair ones you had listed thay have MASIVE heat spreaders)
But if thats a consern for you try a set of Crucial Ballistix Sport VLP (very low profile ram the top dosent even stick out above the ram slot)
