To start I will give some background: I have no money, I am a student, and I act accordingly. This includes getting my media from cough questionable locations, and that involves large files. Now I have 3 other family members that are constantly on YouTube and we all occupy the same router that we got from comcast, which has 5 Ghz on top of the 2.5, but the amount of devices just makes it all go to shit. Now due to the lack of aforementioned cash and a want for greater quality, coax to ethernet and power line are out of the question. From this I have come to the conclusion that an ethernet run is the most effective considering all of this, just putting in the run is phase 0.
phase 0 :
The cable I plan to work with:
So I measured out where along the base board it would travel and it came out to about 68 feet, the 7 feet of wiggle room should be enough to cover any error I have made in my measurements. Now I have considered using these command strips for the most effective and discrete mounting along with the included cable clips.
So once the run hits my room I already have a crappy 10/100 5 port cisco unmaneged switch that will allow me to split off the connection, however improvements to that will come.
phase 1 planning :
So I have an older lenovo x201 thinkpad that I nabbed from corporate surplus a couple years ago. Since then it was partially used as my daily driver until I upgraded, now it sits on the ground unused, now it has a purpose. With the infrastructure pre existing at this point with having the discrete run in place, I plan to put use the laptop as a pf Sense box at the end of the line which will proceed to hook into the modem. At this phase I plan to just use a usb to ethernet adapter to get the other interface I need to use in order to get the hardwired connection through the laptop to take advantage of caching and such. Now the adapter is only the beginning, once I get the cash I plan to get an express card to pci e adapter and then install a gigabit network card in there.
Now with that said, my question to the forum is can I use the network card over the express card and get the performance bump with the interface speed to the caching, general internet speed with upload/download, and other devices I have connected to the laptop directly or will the express card make that benefit null and void?
edit 1: will be posting pictures as things develop
