10/10 for originality, but sadly due to the way a freezer works its not going to be able to give you the cooling power you need... as the computer inside is constantly generating heat it will never get down to its manufactured temps, and it would be very inefficient.
You would be better off running the coolant out of an industrial air conditioner (the ones with the heat exchanger on the outside of the wall) through a normal loop set-up and have the PC in oil to avoid the condensation risks...
Would you advice me as well... I had the idea of using 3M Novec 1230 on a fish tank style set up with a cooler on top to condense the Novec and reuse it. Would it be better to use piping? Not many people have done it.
