I have a Cooler Master 120XL water cooling system on an AMD 8350 and I have an idle temp of 38C, that seems very high to me considering it isn't overclocked at all. After playing Splinter Cell Blacklist on high for 4 hours it was only at 41C so its doing its job in that aspect but I dont know why it idles so high, could anybody explain or give me advice on how to make it lower?
Interesting, I was under the impression that water cooling acted similar to a fridge in that it lowered the temp below ambient, but I guess that would cause condensation right?
Water cooling is still using air to cool (hence the radiators, and usually fans), it just tends to be a more efficient method of cooling than air cooling. *IF MEMORY SERVES ME* refrigerants undergo an endothermic reaction, which is then reversed by pumping electricity into the refrigerant gasses.
As has been said the temp under load seems fine so nothing to worry about straight away in any case.
A few questions:
What did you use to show you the CPU temperatures?
Do you think you messed up the thermal paste when you were setting it up? (Again since the upper temps are fine it seems this probably isn't the case. I am just brainstorming I suppose)
What kind of settings are the fans on for the radiator? As in, have you them on some sort of quite pattern where they wont do much until they hit say 40 degrees and then kick into a high RPM (possibly marked by hearing fans rev up when you launch the game)?
I have never used that program before. I use CoreTemp most of the time as I like the fact I can have it minimized but still see temps down below. Try download coretemp and check idle temp. Im curious.
