the room temp is about 28 celsius and the cpu is at 40 -45 is that safe using a coolermaster hyper 212 evo it went up to 80 while playing far cry 3 blood and metro last light. dragon and was a tad dusty with a few bunnies then later cleaned it up but other games i usually play are league of legends and only goes up by about in the high 50's low 60's.
should i put it back to stock settings or not? sorry for the grammer its like 9:30 pm right now in australia melbourne where i live.
yeah dont worry about the temps when it hit 80 it was during in the summer and my room with the side panel off that it was use to be in since the wifi adapter sucks because having issues with the internet connectivity.
i know its a bit off topic i wonder whats your thoughts about this.
Mobo: asus m5a99x evo r2.0
Temps: http://i.imgur.com/3GbVIlr.png
its facing and blowing downwards towards my gpu due to the motherboard layout for the cooler.
ps unable to get the cpu to 4.5 ghz because it became unstable when testing with prime95 cant remember temps for the prime 95 temps although it hit at the 70's and i thought it was the highest temp it would go but i was wrong later.
it's way too high,last time I checked the 83xx and 63xx had a max temp of 62. Not sure about the 63xx It's either 62 or 70 max. Your OC also seems pretty bad. Maybe it's overvolted. I have an 8 core at 4.5 and it never goes over 64 while gaming,usually at ~58 it stops. Also w/ the hyper 212
Yeah, 80 degrees celcius is too high for even just gaming on the most demanding game. The only software that should produce those temps are synthetic benchmarking softwares such as Prime95.
Well, I use the exact same cooler on my CPU. Granted it's an i7 3770k OCd to 4.5GHz, I'm not sure how much it compares to the FX 6300 in terms of producing heat. But my chip used to produce a lot of heat due to three things, and maybe this can help you out.
1.The TIM on the die was horrendous!! The ivy Bridges were notorious for being hot and that was mostly due to that Intel decided to use a very inefficient and very general thermal interface material on the die. The solution? I delid the CPU and replaced the TIM with Coollaboratory's Liquid Pro
2. The thermal paste I was using on the Hyper 212 Evo was not enough! Everyone gets somewhat different results and experiences when using thermal paste. In my experience, the Arctic Silver 5 that I was using was simply not cutting it; hence, I went with the Arctic MX-4 and that helped a lot!!!
3.I lapped my CPU for a smoother and flat surface to make better contact with the heatsink. I was thinking about lapping the Hyper Evo 212 as well, but I was afraid that the layers buffed out would separate the. However lapping the CPU seemed enough to get great temps! @ 4.5GHz, under load, my temps rarely break past 67C!!!
yeah i dunno why i got these settings off from a guide http://www.overclock.net/t/1348623/amd-bulldozer-and-piledriver-overclocking-guide-asus-motherboard. yeah i dunno why i used the pea method when putting the heatsink on. Last thing i dunno how to update my motherboard, will this makes the temps better or not? oh sometimes it gets up to 65ish after a game of league of legends in certain days
The Hyper 212 isn't the best of coolers. It's good for mild overclocking, not heavy overclocking like that. I would suggest a better cooler like the Xigmatek Dark Night Night Hawk Edition. That compares very well to some of the higher end coolers
The dark knight ii is not that better compared to a 212,I'm using a 212 as well cooling an 8320 at 4.5 and it does well enough,that's it cooling limit,at least for me.
Reset the settings in bios and OC via multiplier on stock voltages. Go for 4.0 ghz on stock voltage. It should handle it ok. then stress test it with aida 64 and see if it fails and watch the temps,I'm 100% sure it will not fail on stock voltages since piledriver cpus can go to ~700mhz on stock voltages over their original clock speed. And also make sure turbo mode is turned off.it overvolts the cpu
Yeah I figured much only the real improvement if i get something from Noctua or getting a corsair h60 since my case is dirt cheap. It is the Coolermaster K350 and watercooling seems not worth it for me price wise.
