hi guys i just got my pc running, and the cpu fans were running fine
i jsut did a fan xpert 2 automatic tuning and the cpu fan has stopped moving
the cooler im using is a phanteks ph-tc14pe, with 3 pin fans, that are plugged into the y spitter included then plugged into a pwm fan adapter that was also included, and the insturctions told me to do this
after the fan tuning the cpu fans have stopped moving, im assuming once the cpu gets hotter the fans will start, but should the fans always be moving?
yeah i wish my temps were a little lower considering i have a massive heatsink and havent overclocked yet, maybe its because the thermal paste was getting moved around for like 15-25 minutes as i was trying to get the heatsink in
Depends on your ambient temperatures and stuff. I get idle temps around 30, on the same chip, with the 12DX. Perhaps my room happens to be cooler, that's just the way it works.
Your temps are well within acceptable limits. 45 under load isn't that bad. It can be luck of the draw, but it appears you have a fair amount of overclocking headroom, as far as temps are concerned.
