i just got a new pc but i have been installing my games and i wit updates from windows and rendering long hd videos i leave it overnight and as its in my room the cpu fan is the loudest thing in there and i cant sleep with it running but
anyway to cut a long story i want to make the cpu fan spin less fast. any software that can do this or am, i stuck wit the noisy ass cpu fan ?
the cpu cooler
http://www.titan-cd.com/Y_product_C_amdK8_e.php?id=429
the rest of the pc
gtx770
amd fx 6350
8GB kingston ram
2TB segate baracuda HDD it makes funny noises when i turn my pc on. not sure if i should worry about that
corsair tx750m as i plan on getting another 770 or selling it and buying 2 of the new amd gpus when i see reviews on them and if they are significantly better and cheaper
asus sabertooth 990fx R2.0
