Hi!
I am planning to build an ESXi server with the Ryzen 5900X and I plan to do it in the SilverStone RM23-502 2U case. I am having trouble deciding when it comes to cooling.
I was originally going to go with the
ASUS ROG Strix B550-A Gaming motherboard and the Dynatron A-24 cooler, but then I noticed that the orientation of the CPU socket on this (and all consumer motherboards) ist rotated 90 degrees compared to server motherboards.
How much of an impact would this have on cooling & general airflow in the case? I will have 3x 80mm front intake and 2x 60mm rear exhaust fans in the case, all Noctua, so it will have good airflow I think.
My problem here would primarily be the cost in going from the around 100$ consumer motherboard, to a 400$ server motherboard like the Asrock Rack X570D4U. Granted, the board would have IPMI and “proper” ECC RAM support, but that does not really justify the huge price bump. The stuff I read in the forums about the driver support and ASRock Rack boards in general is also not confidence inspiring.
Another solution for me would be to get the Noctua NH-L9X65 as a replacement CPU cooler. It barely fits & cools the 5900X, but from what I gather it’s fine if I reverse the fan direction to pull air through the heatsink and reduce the TDP on the CPU a bit.
I hope you can help me choose which solution would be best.
