For some reason one of the computers I built is saying its running at 0 celcius on Open Hardware Monitor and core temp. The cpu is amd a10 5800k quad core. I have no overclock on it and I havent touched the voltage. Im running an intake and exaust fan on the fractel design core 1000. Thanks for the help.
There is some sort of bug, IDK if it's with the sensor, or with the CPU temp monitoring software, but it happens with all APU's in my experience (A8-5600k (x2), C-60, A4-3300) - I think it might be a GPU sensor? IDK what the exact cause is. Use GPU-z, or other GPU temp monitoring software. That seems to read temps accurately enough, and becaue the GPU is on the same die, CPU temps should be identical.
BTW - 0c is freezing (literally, the freezing point of water); you could only achieve temps that low if your ambient temp is below freezing, in which case, I'd highly recommend OCing and over-volting. Again, not likely due to bug.
GPU-z can be found here:
http://www.techpowerup.com/gpuz/
Thanks for the help man
