My stock AMD cooler is loud and i want to replace it. I want a Noctua CPU cooler but I don't want to spend that much money for it. I'm not overclocking ATM so would it be possible to do this and have a really quiet CPU cooler for around $50?
wait, what are you using to cool your cpu? a stock amd cooler? or a hyper 212? much confused. or are you asking for what cpu cooler you can get for 50 bucks?
The Hyper 212 Evo and the Hyper 212 Plus come with very handy self-adhesive mounting brackets. In my experience with the Evo, I was able to put them on another Cooler Master fan and enjoy a push-pull configuration. My guess would be that you can do the same with a Noctua fan, but those typically have round bezels, don't they? Not sure if it would stick correctly to be secure enough to stay on there. Do you have a picture of the fan by any chance? I could tell you if the bracket would adhere correctly or not. If not, I think there are some homebrewed methods of keeping them on there, but I know not of any personally.
He's using a stock AMD one right now, but it's too loud for him. He wants to put a 212 on it and then put a Noctua fan on the 212. That won't give the performance of a true Noctua cooler, but for $50, it won't be terrible.
I don't have either a 212 or the noctua fan. What I was thinking of doing was getting the 212 first, then If I wasn't satisfied with the amount of noise if It made I could get the noctua fan and put it on the heat sink. If the fan doesn't fit on the 212 then I could just use it as case fan and be done with it.
The stock fan on the 212 are relatively silent, although I don't have first hand experience with Noctua fans. I'd say try out the stock 212 and see how it works, the performance with the single fan worked well for me, until I built my new system and threw Bitfenix Spectre Pros on it (they were from a friends system). Those fans in push-pull work pretty well, while staying even quieter than the stock 212 fan while performing relatively the same to the stock 212 fan.
As far as throwing a Noctua fan on it and spending around $50 in total, it certainly won't be a mistake as you could always use the fan somewhere else in your case if you do decide to change your heatsink again or go water cooling.
