Hey dudes and dudets,
Hows things?
So I was wondering if I could please get some advice regarding some lacklustre crypto mining performance on my Vega VII.
I had one lying around (long story) and noticed on whattomine.com that it had some stellar mining performance so I decided to give it a crack.
https://whattomine.com/gpus/30-amd-radeon-vii
I’m using windows 10 and ethminer (which uses the ethash algorithm) to mine Ethereum. I should be seeing about 80Mh/s ish on windows (switching to linux soon, another long story) but I’m only seeing 45 Mh/s. I don’t have any background processes running that should be utilising the GPU so I can’t explain why such a difference.
Would anyone have any suggestions as to what to investigate to boost the performance?
